Is your gas tank filled completely and are you parked on a hill ?
Take the gas cap off and listen for any pressure hissing.
Replace cap and try again. SWITCH ENGINE OFF FIRST.
Could be just too much fuel in tank.
first of all check for at least 12 volts from the battery and the charger, you can test this using a multimeter, if the battery doesn't show any volts, lift up one side of the blue plastic housing on the top and verify that both the positive and negative wires are plugged in
make sure you get the right pump, you need to know your tank size. then take off your bed. you have i believe 6 bed bolts, disconnect tail lights (unplug from underneath) remove bed grounding strap 1 screw, remove bed with help. Disconnect wires, unscrew fuel pump, replace pump. Reverse order to replace bed. jim
scroll down the images till you see the set that they have. click on it when the page opens look for instructions... click on that it should have them. note i did see at least one recall notice so make sure that doesn't involve the set you have
