The solution to your problem is the Nokia Master Code. For your particular device your master code is 0053156335. On your device you will need to type #pw+0053156335+1#
my friend in this phone they use a digital mic that can be easly damaged since you said that you dropped it surely its brkoken so yoou have to replace it in good service center.
Option No. 1 is
*#7370# is the code to reset everything, including contacts, sms, emails, all application, everything. But you need the 5 digit security code to do this.
Option No. 2
Since you have forgot the lock code, you can try this thing. Using PC Suit, take backup of your phone contents, then update the phone software.
Option No. 3 Unlock Security Code using Memory Card
Steps to unlock ur sec code. 1. Off Ur mobile. 2. remove battry 3. remove memory card 4. On ur computer and plug in ur memory card. 5. insert ur memory card. 6. unzip the attachment file and place it to ur memory card e:\system\recog 7. now insert ur memory card into ur mobile and switch on the fone. 8. now if it ask for code type 12345 and ur mobile unlocks. 9. Every times u restart ur mobile it will unlock ur mobiles security code.
You need to clarify whether microphone or its connection bad or system causing the problem. I suggest you to try with external bluetooth or normal headset. If sound microphone works with headset you need to have microphone connection be fixed
you have to remove the back of the phone with a small tri screw driver. underneath the board in a corner there is a flat cable that connects the screens to the board. It came loose. press the flat cabe back into the the board chip. they will lock together. the screens will work.. I just did this with my sons phone.
