You can easily get the Ip-details from , http://www.ip-details.com/ it is very reliable and accurate.
Its default ip address is 192.168.1.254 you can try to access it using your internet browser, check it out
If you can see the setup menu of the router then you should change your password.
Please see page 6 of the document in this link. there should be similar setup menu for your router.
Hope this helps.
Go to the youtube link below and watch the instructional video on how to do this.
http://www.youtube.com/watch?v=BK0L7_w7oSc
here is another video on this, watch both and see which one u understand the best.
http://www.metacafe.com/watch/415025/how...
SOURCE: Help setting up hwr54g as an access point
Yes there is an easier way! Just setup the router as you would any normal setup. Follow the directions to set it up for the first time. What you want to do is have the put in all of your information that you need for it to communicate with your Modem. This will automatically place the router onto your network. Now the part that I believe you want is for this to be secure! Well setup either a WEP or WPA these are both encryption Protocols that will denie access to anyone other than you or someone you allow to access your network wirelessly.
You do not really have to go through all of the trouble of setting up specifics. As long as the two devices communicate the router and the modem will do the rest. I do this everyday in my daily work day! Anymore quesitons please feel free to ask!
I have my IP address from "IPCONFIG", but when I put the IP address into the address line I cannot ssee where I can change the password for the router
