I need the instructions please
Hi. I would advise both of you to try a flag clear first to see if you have any program left.
Turn key to program. Power off at wall.
Hold RECEIPT FEED, and turn power on at wall.
Wait 10 seconds, then let go of RECEIPT FEED.
When you see 'FFFFFFFFF' press SUBTOTAL.
Turn key back to REG and try it.
If you still need help, let me know.
Mark
I have a Casio - 3700 cash register with a code E08 after tryng to fix an error code E04
I have in my casio cash register ce3700,problem this precent
e08
An E04 error is an indication that you've lost the program in the register, usually due to a dead back-up battery. Occasionaly you can do a Flag clear and save the progam.
To Flag clear the CE-3700:
Unplug the register
Turn the key to the X1 position
Press and hold the Receipt Feed button
Plug in the register
Release the Receipt Feed button
You should see FFFFFFFFFF in the display
Press Subtotal
Turn key to REG, sign on a clerk and try it.
If you don't get FFFFFFFFFF or this does not work the only other solution is to MAC the register and reprogram it.
To Mac the CE-3700:
Unplug the register
Turn the key to the PGM position
Press and hold the Journal Feed button
Release the Journal Feed button
You should see 0000000000 in the display
Enter 12001
Press Subtotal
This completely clears the memory of the register and sets it back to factory defaults all programming and totals will be lost.
E08 code is a sign in clerk code : )
My register says e10 it is a casio pcr-t265
SOURCE: I have a Casio CE-3700 cash register. How do I
tina -
I found the service manual here:
ftp://ftp.totalpos.co.nz/Oldmanuals/Casio-CE3700.pdf
It is New Zealand, and the file is a little over 3 MB. If you have a problem, contact me and I can email it to you.
It has a section on programming the CE-3700.
Michael
I HAVE E04 ERROR CODE ON MY CASIO CE-3700 REGISTER PLEASE HELP
I want to change the tax rate How can I go it?
i have Tried powering off at the the wall pressing reciept feed button for 10 sec then releasing and it cleared the E04 error but not its frozen i can't program or type in and number value eg. 0123456789
an error code E004 display, what should I do
error code E004
i have casio ce 3700 cash register and i have problem e 01 and noies come beep any one help me plz.
I have a ce 3700 cash register, and my number display is stuck on 0.0.0.0.0.0.0.0.
Add a CoIhave a cah register ce 3700 and the number display is stuck on 0.0.0.0.0.0.
