It's not getting gas. Possible wrong mix oil to gas, but not real likely. Possible sat over the last winter with gas in it and varnished. I'm guessing this is the one, more likely than not. take cover and filter off and clean and bag 'em. pour carb cleaner in the carb and soak overnight. Dump out (carb cleaner and old gas)into a sealable jar or can and fill with straight gas and soak an hour and dump into trash gas/carb cleaner. Use a bicycle pump to blow air into carb to dry it. At most use a computer air can. Then start with the right gas/oil mix, prime it, set the trigger and choke and drop start. (It helps to have the spark plug out during the soak. Then clean it and sandpaper the gap and the magneto area on the flywheel).
