20 Most Recent
Poulan P3416 16Inch 34cc 2Cycle Gas Powered Chain Saw Questions & Answers
Poulan pro 16 34cc wont pull gas into piston chamber
A few possibles
- Spark assestor screen clogged
- Piston Ring struck
- Cylinder and piston damage
- Metering lever set too low.
To check for struck ring or cylinder damage, remove the muffler and look the exhaust port,
Note: Your engine is not a 34cc but is in fact a 42cc. If you need a cylinder it is now list as NLA but I can give you the optional version and piston part numbers if needed but they need to install as a set.
How to adjust zama carb
start with your screws turned in. adjust the high screw to 1 turn and the low to 1/2 turn. this should get unit running. once running then you can fine tune the carb
Will not stay running
Clean carburetor-verify fuel line blockage-clean filters-make sure your gas/oil mix is correct-use fresh gas. They shut down frequently when setting them down-Increase RPM at Idle.
