Reseated? How Rick?
Did you;
1) Have the computer unplugged from power, and follow Anti-Static Precautions?
2) Did you clean the top of the processors, and bottom of the Heatsink's - Thoroughly, and properly apply new, fresh thermal paste?
[ If they had thermal pads on the Processors, remove them, throw them as far as you can.
One, they are JUNK. Two, you cannot reuse them.
The imprint has been made, and you cannot imprint over.
{The Heatsink, and Processor make an imprint on a thermal pad. The pad is squeezed down. You cannot re-squeeze again, and make a successful complete contact. A thermal pad also dries out a lot faster than thermal paste. Poor design ]
3) The LED lights you refer to are Diagnostic LED lights.
A, B, and C are Yellow.
The Power On LED light is Yellow,
Dell Support > Precision 470 and 670 Workstation Desktop PC Users Guide,
http://support.dell.com/support/edocs/systems/ws670/en/ug_en/index.htmSolving Problems
http://support.dell.com/support/edocs/systems/ws670/en/ug_en/solve.htm#wp1252394Power Problems:
If The Power Light is Amber and Green or Steady Amber;
A device might be malfunctioning or incorrectly installed.
- Remove and then reinstall the memory modules.
- Remove and then reinstall any cards.
- Remove and then reinstall the graphics card, if applicable.
Diagnostic Lights before P.O.S.T. (Power On Self Test)
A, B, C, are Yellow, D is blank or Off.
BIOS is not executing - Ensure that the Processor is seated correctly, and restart the computer.
http://support.dell.com/support/edocs/systems/ws670/en/ug_en/advtrbl.htm#wp1057482Almost sounds like a problem with the motherboard voltage regulator circuit, if the Processors were handled with Anti-Static Precautions being observed, and new thermal paste being used, after proper cleaning.
{A Processor is the MOST susceptible computer hardware component to Static shock}
Motherboard Voltage Regulator Circuit
A series of Electrolytic Capacitors on the motherboard, (Yes, in a Series circuit, also), that among other duties, regulate voltage for the Processor/s.
http://www.hardwaresecrets.com/article/616Computer unplugged from power, Anti-Static Precautions observed, remove the motherboard, and visually inspect all 'caps' on the motherboard,
http://www.capacitorlab.com/visible-failures/index.htmPost back as to your findings, in a Comment. (Believe upper right of your page, blue Comment)
Regards,
joecoolvette
