Dewalt dw005,stopped working when i was chisiling ,slight smell,when i put my ear to drill and pull trigger it starts to make the contact noise at start but chuck does not turn/chisel.
SOURCE: Dewalt XRP Drill Chuck will not come off
you need a special jig to remove the chuck on this kind of drill
SOURCE: 24v dewalt dw005 was using my drill in chisel
Hi, You should take it back while the warranty is still fully intact as this is a problem and will not resolve itself.
Good Luck to you, this should Fixya!
SOURCE: Replacing a power cord for a Dewalt electric drill
some of the dewalt drill switches have a one way trap (like) for the wire. you push the wire in and the harder you pull it gets tight on its self. your wires go in the bottom of the trigger look right on top of each wire there is a small **** (no bigger then 3/16) for a flat head screw drive. In the **** you will see a small lever, it needs to be turned at the same time pull. It will help to have a friend.
SOURCE: got a broken drill chuck i cant get off (Dewalt)
first remove the chuck retaining screw LH thread, next shift the tool to the drill only position and the low side. Find a bent handle allen wrench and insert the short piece into the chuck and clamp down, place the chuck with the long portion at about a 30 degree so you can strike it counter clockwise, usually a block of wood or work bench will do and then get a hammer and safety glasses and hit it, it might take a couple times but it will come off
SOURCE: the chuck is stuck on 18 volt dewalt drill
It is not the chuck that is stuck, it is probably the armature. Probably a problem with the brushes. Since it is so easy I would try first unscrewing the caps and pulling the brushes out to see if things spin then. If the brush will not come out then it is probably jambed and you would have to take the drill apart. If you take the brushes out and still have a problem, at least one reasonable but simply checked problem is eliminated.
It's probably the switch; mine judders and works kind of. Slight burning smell coming from it, dismantled it to discover that the switch has started to burn out, so far no luck finding a replacement.........
JCB are totally useless, no help from their support phone number!
