1.FACE THE VEHICLE SO THAT BATTERY IS ON YOUR RIGHT;
2. REMOVE THE BLACK PLASTIC PIECE THAT RUNS OVER RADIATOR BETWEEN HOOD LATCH AND FAN. IT IS ABOUT 53 1/2" LONG AND HOLDS THE HOOD PROP CLIP. (3 PLASTIC PUSH RETAINERS & 2 SHEET METAL SCREWS);
3. REMOVE THE GRILL ASSEMBLY UNDERNEATH THE PIECE IN STEP 2 BY PUSHING DOWN FIRMLY ON 4 RETAINER CLIPS WHICH RUN ALONG THE TOP. USE A WIDE SLOT SCREWDRIVER. PULL UP GENTLY ON GRILL ASSEMBLY. IT WILL POP OUT. THE GRILL ASSEMBLY EXTENDS UNDER EACH HEADLIGHT ASSEMBLY (HA) AND IT DISPLAYS THE CHEVROLET LOGO IN THE MIDDLE. MY GRILL ASSEMBLY POPPED OUT EASILY AND ALL THE OTHER RETAINER CLIPS ON THE BOTTOM AND BENEATH AND TO THE SIDE OF HA WERE AUTOMATICALLY RELEASED WITHOUT ANY FUSS;
4. ON TOP OF HA SEE ONE TAB (ABOUT 1" LONG)ON THE RIGHT SIDE AND ONE ON THE LEFT (THE ONE ON L IS CLOSER TO THE FENDER);
5. PULL UPWARD DIRECTION ON TABS. THEY WILL SLIDE UPWARD A COUPLE OF INCHES AND WILL RELEASE THE HA WHICH YOU CAN THEN PULL OUT TOWARDS YOU;
6.AT BACK OF THE HA, REMOVE 2 ROUND RUBBER CAPS (ABOUT 4" IN DIAMETER)--ONE FOR LOW BEAM--ONE FOR HIGH. REVEAL BULBS. UNSNAP THE WIRE HARNESS FROM BULB BASE AND TURN BULB 1/4 TURN CLOCKWISE (REMEMBER YOU ARE FACING THE TRUCK)
7.REPLACE BULB(S). #9006 BULB IS GRAY-BASE, FOR HIGH BEAM ON OUTSIDE. #9005 IS BLACK-BASE, LOW BEAM TO INSIDE OF HIGH BEAM.
CHANGING HIGH AND LOW AND REASSEMBLY TOOK ABOUT HALF HOUR. GOOD LUCK.
ALTERNATIVE:
IF YOU ARE REPLACING THE PASSENGERSIDE HEADLIGHT JUST REMOVE THE AIR FILTER COVER AND PULL PLUG OUR FROM BEHIND HEADLIGHT AND REPLACE. BE CAREFUL HANDLING LIGHT BULB.
TO CHANGE THE ONE ON THE DRIVER'S SIDE JUST REACH IN FRONT OF THE BATTERY TO ACCESS THE PLUG AND HEADLILGHT. TOOK ABOUT 5 MINUTES. ENJOY YOU TRAILBLAZER, GREAT TRUCK.
Thank you for using fixya
