Just slide the cover to take a shoot but the camera remains in USB MODE. i´m alwais unplug by soft. I´m change the batteries but didn´t work.- Thanks and sorry for my poor english ;-)
The camera still in USB MODE. just try to taking out the batteries and the memory card but nothing happens. I cant acces to the soft menu.The camera still in USB MODE. just try to taking out the batteries and the memory card but nothing happens. I cant acces to the soft menu.
My Finepix A340 is also stuck in USB mode. When plugged into the computer via USB, I can access the photos on the camera. But when unplugging from USB, the mode remains. I've taken out (and changed) the batteries and memory card. I've also tried replugging into the computer and removing it again. Help!My Finepix A340 is also stuck in USB mode. When plugged into the computer via USB, I can access the photos on the camera. But when unplugging from USB, the mode remains. I've taken out (and changed) the batteries and memory card. I've also tried replugging into the computer and removing it again. Help!
You can't post conmments that contain an email address.
One problem with many point&shoot cameras is that they expect you to point and shoot, without fiddling with things like aperture and shutter speed. This camera doesn't give you any direct control over the aperture, which is restricted to a range of less than one full f/stop in any case. About the best you can do is to select the Portrait or Sport mode when you want a wide aperture and the Landscape mode when you want a small aperture.
The Fuji FinePix F470 camera is an excellent device. Most of the controls are computerised in such a way that makes picture taking and viewing less stressful. Changing from shoot mode to playback mode is by the press of the play button which looks like an arrow the zoom lens is not manually adjustable it adjusts by the press of the W and T buttons. Here is a link to help you download the brochure, User guide and quick start guide for the camera: http://www.fujifilmusa.com/support/ServiceSupportBrowse.do?prodcat=842410&sscucatid=664271&sscucatid=664272 Hope this soultion has been helpful?
Hello, To solve this problem you need to use the SP shooting mode. Replace battery with new High power ones. and switch ON keeping pressed the PLAY Button. If still does not retract disable the flash and repeat the operation without the XD/SD Memory Card inserted. It will then close the shutter magic. Regards, PDG
Reconnect the camera to the computer. and then go through the closure sequence one more and do not unplug the camera untill you are told to do so.
Aalso get onto the FUJI tech support team.
I suppose you've already turned the dial?
Yea, on my camera there's dial ontop to turn to select the display mode, and then I turn it to the "shoot" mode, its usually a camera icon.
Completely open lens cover by sliding the lens cover all the way to the right until you hear two clicks. The first click will put the camera into playback mode. The second click will put the camera into shooting mode.
