SOURCE: white 3-4 thread overlock speedylock model 1600 sewing machine manual needed
Manuals for all types of sewing machines can be downloaded from sewingmanualss.com.
SOURCE: I can't find the manual for White's sewing machine with model 675
The folks at White sent me this reply to my request for a manual.
Thank you for contacting White. Unfortunately the instruction manual that you have requested is no longer in print.
We do however, have a free copy that you may download from our sister company "The Singer Sewing Company's" website.
To download your free copy of your "White" manual, please follow these steps:
1) Go to www.singerco.com
2) From the "I am looking for" drop down menu, select "Instruction Manuals".
3) To find your particular manual, enter W and then your model number (W1600) in the search box.
4) Click on "Search".
The manual is 31 pages, in pdf format.
SOURCE: PFAFF 362 Sewing Machine: The shift
I just fixed this on my pfaff 230-the problem is the needle position dial-the middle dial with the chrome lever on the right-has froze up .
remove the dial-it doesn't come off by the screwhead in the middle of the dial ,the screw you need to loosen is the one under the wider end of the part of the dial you hold-you will need a glasses screwdriver.
once it is off ,heat the exposed shaft with a heat gun while turning the shaft back and forth with pauses for dripping 3 in 1 oil on the shaft so the heat melts the hardened grease and draws the 3 in1 in to flush out the old grease and lube the shaft.
eventually you will be able to turn the shaft easily-then when it cools off replace the plastic dial.make sure your upper dial is on "0" there is a cam on it that will push down the other end of the chrome lever.
This will work-there is no plastic in the shaft and arm assembly to melt and you don't have to dissasemble from the top-that sucks.
SOURCE: Need Manual for White sewing machine Blue Jeans Machine
You can find it here:
http://ifixmachines.com/index.php?page=shop.product_details&product_id=3289&option=com_virtuemart&Itemid=54
