20 Most Recent
White Sewing Mighty Mender WW100 Mechanical Sewing Machine Questions & Answers
Repair bobbin case on mighty mender W100
Did anyone ever figure it out? I can’t get it back in either. Got this for 10$ and the machine was brand new. Figured it would be good to start with but the thread keeps bird nesting on the bottom. Tried adjusting tension, rethreading.. now I just took case out to tighten screw for the bobbins tension and cant get it back in. Thinking about throwing in the towel and buying a better machine.
Bobbin holder doesn't spin
Be really sure that the thread is threaded properly. Correct size needle for the material, and no cheaper thread. It does make a difference.
Gemsy gem20u43
hmmmmmm, that could really be anything! Can you be more specific?
W100 download manual
gfdhgfdg,./ fnl;mgfdfdfdfddsdsdsDSfDSfDSfdsFdsfDSFDSFDSDSFDSfdsdsdsfffffdsffsdfdsffdsdsdsdsdssdsfsdsdsfdfdsfafg
Loading the bobbin and adjusting the tension.
Loading the bobbin for this maching is fairly simple. First thread the machine. Then after placing the bobbin in the machine pull the thread out through the first notch and back through the second. (The end of the thread should be going in the direction of the little channel on the left side of the bobbin area.) Now what I did was make a loop with the end of the thread and pushed it under the casing below the needle. Then if your machine is threaded correctly you should be able to turn the knob on the right side of the machine so the needle goes down and comes back up once. If you've done it right the bobbin thread should come up in the correct spot.
Can i get a free
Check the singer website for a operation manual
Go to the singer website
Go to the home page
At the bottom of the page look for instruction manual--click on it
It will take you to another page
In the box put the model number (example w200) & click search
They have a free download
Looking for a instruction book
They have a free instruction manual download on singer website
On the homepage at the bottom look for instruction manual & click on it
It will take you to a page where there's a box put in the model number WW100
Then click search
