Question about MSI K8MM-V Motherboard
Unable to use SATA hard disk with existing IDE Hard disk
I was using 80 GB IDE hard disk and was working fine. Lately I want to update with another 250 GB SATA hard disk but the mother board is not detecting it. I have even updates the bios with 1A version. Please suggest.
  • 2 more comments
  • abhinav123 Apr 10, 2008
    @Mike
    Thanks for the solution I will try this out at my home this evening.
    @Riinuka
    My motherboard is K8MM-V with bios 7142-1A(latest). In the bios the option On Chip SATA is enabled and DMA Access is allowed. RAID option is also enabled. I would really appreciate if you shared some solution other than Mike has discussed.
    Thanks
  • abhinav123 Apr 12, 2008
    Hi Mike and Riinuka,
    Thank you very much for your solutions. I got my issue fixed. This was making me restless since 3 weeks. At last it got sorted out, I definately owe you something. I wish I could help you guys in some way. Thanks again
    Abhinav
  • nareshbabu7 Apr 19, 2009
    MSI -K8MM-V VIA K8M800+ VT8237R CHIPSET.
    Hi, I have recently purchased a Seagate 250GB SATA Hard disk. I was able to successfully install the hard disk,I USED to use 80GB IDE Hard disk which i upgraded with 250 GB SATA HDDbut not able to detect the new one if i use as slave or Master HDD also,pls suggest me how to resolve this issue on this mother board -----
    Any help here would be greatly appreciated...
    Please post here or e-mail me at nareshbabu7@in.com/naresh.babu7@gmail.com
    Thanks in advance
    Naresh
  • Shannon Mantel May 11, 2010
    If you can post the model number of the board you are using, we could give you some more information. Generally, though, older boards can't see drives larger than 137GB without further updates to the BIOS.
    You say you are wanting to use a SATA hard drive now, have you made sure that your SATA controller is enabled in your BIOS?
    President:
  • 2,351 Answers
Hi abhinav13, please disconnect you're IDE. (do not remove it).
You're board only supports SATA 1.0 which is 1.5BG & not the SATA II at 3.0GB. Knowing that you may need to use the jumper to set the drive to 1.5GB. Once you are sure the drive is set correctly than hook it into the PC. If after disconnecting the IDE & SATA drive is shown in the bios. Set the jumper on you're IDE to function as a slave drive.
Enter the bios again. If you do not find the SATA drive listed than your onboard SATA controller is defective. You can not fix that.
So hate giving out bad news.
Luck!
Mike
Posted on Apr 09, 2008
    Scholar:
  • 50 Answers
I verified that you have the most recent drivers for your board. Like Mike said, your board can only support a 1.5GBps transfer rate. Most SATA drives -should- be backwards compatible. If you can give me the specifics on your particular hard drive, it may provide a bit more insight.
Generally, though, the back of the drive will be the same. You will need to take a jumper, and assign it to the back of your hard drive according to this diagram.
You'll need to disconnect any other drives that are connected to your machine, including the other hard drive and any CD/DVD drives you might have. Connect only the SATA drive, and then boot the system. See if your BIOS sees it.
If your BIOS allows, check to see which channel is assigned to which port. (i.e. IDE 1 is assigned channel 1, SATA 1 and SATA 2 make up channel 2...). If you see where the hard drives are supposed to be appearing, try to make it manually "see" the drive.
If you still need further assistance, I've got some more information that I can give to you. Try these first to see if they help you.
Posted on Apr 10, 2008
How to upgrade ST380011A 80GB seagate hard disk to 500GB
First you check your Hard Disk connectivity type SATA or IDE. Then purchase same type of connectivity Hard Disk as your wish. Seagate Desktop internal Hard Disk Available in market (160 GB, 250 GB, 320 GB, 500 GB, 750 GB, 1 TB, 1.5 TB, 2 TB, 3 TB).
Nov 20, 2012 | Seagate Barracuda 7200.7 ST380011A 80 GB...
I attached a sata hard disk in addition to the existing ide hard disk drive in my pt800ce-a motherboard. But the system cannot detect the said sata hard disk. what should i do?
If your existing system is IDE motherboard your new SATA drive will not work as it will have compatibility issue, also the MB will not support it.
The same goes for RAMs, 2 uncompatible RAMs will make the PC slow down or keep shutting down....
I guess you have used an adaptor to connect a SATA disk/cable to the IDE MB, check that, it may be the issue also.
Regards
pls leave a feedback and reply
Nov 11, 2010 | EliteGroup PT800CE-A Motherboard
I have sata 80 gb hard disk not working i have sata160 gb hart disk can i replase carcit
If you are asking if you will be able to replace the first one with the sata one ...the answer is that almost all Hdd will fit in any desktop ...(I assumed that you are talking about a desktop ) ..with the condition that you have a SATA bus available ...on the motherboard..and all you will need if you do not have is a cable for sata and a power supply cable to attach on the existing ones..after that reinstall the computer ..and it will work ..
Even if your motherboard is not equipped with a sata bus...you can always get an adaptop ..sata to IDE and plase it like a regular ide drive ..
Jul 31, 2010 | Computers & Internet
500gb hard disk supported by intel D101GGC
Hey ROY_GV,
This D101GGC Motherboard supports both IDE and SATA.
Regards,
InfDev
Mar 05, 2010 | Intel D101GGC Motherboard
Unable to install RHEL5 in D101GGC
http://www.linux.iastate.edu/rhel5/...READ THIS IT WILL SOLVE THE PROBLEM.RICHARDM69
Nov 07, 2008 | Intel D101GGC Motherboard
Unable to detect 250GB Seagate hard disk on P4 PC
you need bios update
download bios express installation file
install first any 40 or 80 gb ide harddisk install windows and run express installation file
your motherboard will update your bios
download from http://www.updrivers.com/search/d845glly
or
http://www.updrivers.com/getdriver/Motherboard/Intel/D845GLLY-BIOS/10018.html
Oct 17, 2008 | Intel D845GLLY Motherboard
Sata drive not detected
just no other solution except upgrading BIOS properly
Sep 24, 2008 | Seagate Barracuda 7200.10 500 GB SATA Hard...
Samsung 80 gb Hard Disk Un allocated
All ways best to used new cables (sata/Ide) I like to set jumpers on the HD's never cable select. Also try installing one harddrive at a time. Second make sure in bios is set to boot from main HD.
May 12, 2008 | Samsung SpinPoint P80 SP0802N 80 GB Hard...
Problems Installing my 160 GB Seagate SATA HDD
Check the SATA/RAID controller setting. It could have been set to [Disabled] Refer to your user?s manual for a detailed description on how to enable the onboard SATA/RAID controller by adjusting the jumper or BIOS settings. Regards SparkGap
Sep 24, 2007 | ASUS P5RD1-VM Motherboard
MSI K8MM-V Motherboard Logo
811 people viewed this question
Top MSI Computers & Internet Experts
vsri9
Alun Cox
David
David
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
