Intuit QuickBooks Pro 2010 Full Version for PC (28287024175) Logo
Posted on Jun 01, 2010
I have several stores under the same company. How
I have several stores under the same company. How do I set these up in QB? I need to be able to run reports for the business as a whole and also for each individual location.
Anonymous
Level 1:
New Friend:
  • Contributor 60 Answers
  • Posted on Aug 17, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
60
Questions
0
Helped
16725
Points
67
You can use class for each store. You can activate "class" in preferences. Be sure to segreggate expenses and income for each class (store). You create pL reports for each class, a group of classes and or all classes.
www.cpahispano.com
2answers
2answers
Error installing quickbooks 2005
I don't know what type of error you face while installation of QuickBooks but i share some of Intuit common error so choose the right one for you Links for installation errors . if still not able to get and need any technical help follow Intuit Tech Support .
3answers
I am trying to instal quickbooks pro 2008 but error 1603
Error 1603 is related to insufficient rights to install QB. Please follow these steps to resolve this issue. Assuming you have Win XP. 32 Bit OS.
1. Remove QB from Start>control panel>Add/remove programs. {IF YOU FIND ANY QB INSTALLED].
2. Rename all intuit folders to Intuit-old. You wil find these folders here:
  • C:\Program Files\Intuit
  • C:\Program Files\Common Files\Intuit
  • C:\Documents and Settings\All Users\Application Data\Intuit
  • C:\Documents and Settings\All Users\Application Data\Common Files\Intuit
3. Then install QB using QuickBooks.msi . You will find it inside QBooks folder in your QB disc. Right click on the DVD / CD drive and click Open/Explore. Then go to Qbooks folder, find Quickbooks.msi and then run it. Follow the wizard and then install it.
IF STILL ISSUE IS UNRESOLVED, THEN REMOVE AND INSTALL MICROSOFT .NET FRAMEWORK 2.0 SP2. To do it, please follow.
1. Download and install .NET removal tool from:
http://public.blu.livefilestore.com/y1pM-hUF1x_Oqpme4sYbkLY1eFfh7z7FTyANwGAK1PQgJMwhILtFzMj7WXQJtjfH39GalpsBeQRzeQHXRlbO9w1gA/dotnetfx_cleanup_tool.zip?download&psid=1
then save it and unzip it . Then run it. Select Allversions in the box where it will ask to remove .net framework from the computer.
2. Download .NET framework 2.0 SP1 and then install it . you can download it from:
http://www.microsoft.com/downloads/en/details.aspx?familyid=5b2c0358-915b-4eb5-9b1d-10e506da9d0f&displaylang=en
click on DOWNLOAD next to NetFx20SP2_x86.exe. download it and install it.
3. Restart your computer and then again install QB.
IF STILL YOU GET ANY ISSUE, REPLY WITH FOLL :
1. WINDOWS VERSION.
2. are you installing QB using a disc or downloading from the Internet?
3. Any Antivirus on the computer?
2answers
Can i convert cash register express data to excel and the to qb
certainly. most reports have a "save as excel" option once you generate them (at least, the full sized ones). CRE does have a direct QB interface however that is prob easier. you can also run direct queries off the database itself and save the results of those as an excel file.
3answers
Quickbooks Pro 2007 has stopped working. when i
uninstall the software 100% reboot the machine so the information obtained in ram is not going to interfere with new installation. using your original cdrom that came with the kit, install your quick books 2007 software register it with the original code and product id sequence numbers. when it tries to run theirs 3 things happening now. the program in initializing it;s visual c run time libraries. and well as calling the dynamically loaded libraries from the windows directory and other locations. if a program was removed that used these files and it was uninstalled with the files then it is possible you will have to install qb from scratch and use the qbw or quick books workspace file to run your company files afterwords. backup the qbw files encase of problems. this is often tell take sings of viral or system melware. then scan with your virus software. and see if anything was crashing the program. other options involve system files missing that are used. good luck.
3helpful
Error message Library not registered
I got the message "Line 25: Library not registered" after uninstalling QuickBooks Pro 2009 and trying to run my old version of QB Pro 2006.
(I had installed 2009 version to upgrade my QB2006 Pro version but got into problems with multicurrency support not being supported in the Canadian QB Pro 2009.)
Fix is VERY easy and I think it applies to anyone trying to run an older version of QB Pro after uninstalling a newer version.
Fix is to find the file "reboot.bat" located in the program files associated with the older QB version.
In my case it was found in "C:/Program Files\Intuit\QuickBooks Pro" folder.
Just double click on the file to run it. This file tells the system where parts of the QB program are located including the DLL libraries it needs. After running this file you should be able to run your old QB version OK. No rebooting necessary.
Quickbooks Premier 2008 will not open quickbooks 2008 Pro files. What's up?
PLEASE REMEMBER THERE SHOULD NOT BE ANY PROBLEM IN OPENING A QB PRO 2008 COMPANY FILE IN PREMIER 2008. THERE SHOULD BE SOME OTHER REASON TO IT .
If you need the resolution, please reply with the foll :
1. Which Windows Version you have . Is it Win XP or Vista or 7?
2. How do you try to open the company file ? Please list the steps .
3. Do you get any erro msg ?
4. Does QB crash?
5. Do you have a backup company file QBB or main company file QBW ?
Please try these steps or reply to my questions:
1. Change the location of the company file.
2. Disable UAC.
2. Rename the company file .
3. Delete the ND and TLG file .
I bought a new laptop and need to transfer my quickbooks pro 2008 from old computer to new one
So long as you have a valid, REGISTERED copy of QBPRO, this should be no problem... You'll need the phone number and ZIP code of the person or entity under which you entered the registration.
Install QB Pro 2008 on the new laptop, register it (you'll need an internet connection) and go ahead and click on help...update quickbooks and let it do it's thing.
Then (If you're using an XP machine...) COPY your intuit directory (usually located at C:\documents and settings\all users\shared doctuments\intuit) over to the new machine in the shared documents folder.
After you have copied the data, open QB Pro and choose "open an existing company", then navigate to where you placed your intuit files and open the company in question.
4helpful
4answers
Upgrading from Quickbooks Pro 2003 to Quickbooks 2009
I would not open up the company file in 2009. Open your 2003 Quickbooks, make a backup and then restore the back up in 2009. If you do run into problems you might want to upgrade into 2006 and then to 2009. (you will need to find someone who can do this for you if you don't have a 2006 version. I can help you with that if you need it
Top Intuit Computers & Internet Experts
Ngoro
ADMIN Andrew
ADMIN Andrew
Are you an Intuit Computer and Internet Expert? Answer questions, earn points and help others
