20 Most Recent Intuit QuickBooks Pro 2008: Windows Questions & Answers
This error can occur when:
  • Data is converted or restored over a network.
  • Several computers are acting as host for the QuickBooks data file.
  • QuickBooks is unable to communicate with the server.
  • There is data damage in your company file.
If the error occurred when you were restoring a company file from a backup or updating a company file to a newer version of QuickBooks over a network:
  1. Copy the backup file (.qbb file extension) or the company file you want to update (.qbw file extension) to a local hard drive.
  2. Restore the backup or update the company file.
  3. Copy the restored or updated company file back to its original location.
If the error occurred when you were trying to open and use a company file:
  1. Update QuickBooks to the most current release on all computers that open the company file.
  2. Close QuickBooks on all the computers with access to this company file.
  3. On the computer you select to host the company file, switch to single-user mode, and then back to multi-user mode:
    1. Open QuickBooks and open the company file.
    2. Choose File > Switch to Single-user Mode.
    3. Choose File > Utilities > Stop Hosting Multi-User Access.
    4. Choose File > Switch to Multi-user Mode.
    5. Choose File > Close Company to close the company file.
  4. On all other computers that will use the company file, stop hosting multi-user access :
    1. Press and hold Ctrl while you open the QuickBooks program and continue pressing Ctrl until QuickBooks opens completely. This opens QuickBooks without opening a company file.
    2. Choose File > Utilities >Stop Hosting Multi-User Access. If that option doesn't appear, the computer is not hosting and no further action is necessary.
    3. Repeat steps 4.a and 4.b for each computer other than the host computer.
  5. Configure the QuickBooks server for multi-user access:
    1. Click the Windows Start button and choose All Programs > QuickBooks > QuickBooks Database Server Manager.
    2. Click the Scan Folders tab.
    3. Click the Add Folder button, select the folder that contains your QuickBooks company file, and click OK. Repeat this step if necessary to add additional company file folders.
    4. Click the Scan button to begin scanning. After the scan is finished, the company files in the scanned folders are configured for multi-user access.
  6. Open the company file in QuickBooks. If you receive the same error message, refer to Settings required for firewalls to make sure your firewall is properly configured to allow QuickBooks access to your company file.
  7. Open the company file in QuickBooks. If you receive the same error message, open a different company file or a sample company file located in one of the folders you scanned with the Database Server Manager.
    • If no company file will open, reboot the host computer and try again.
    • If other company files open without error, the company file generating the error message may be damaged. For more information refer to Verifying and rebuilding QuickBooks company data.
Intuit... | Answered on May 29, 2019
Update your Quickbooks, run reboot.bat, restart your computer and then restart Quickbooks
  1. Open the folder containing the reboot.bat file:
  2. Windows Vista: Right-click the QuickBooks icon on your desktop and select Open file location.
  • Window XP:
    1. Right-click the QuickBooks icon on your desktop and select Properties.
    2. Click Find Target.
  1. Double-click the reboot.bat file
Intuit... | Answered on Nov 27, 2018
I had to reinstall Quickbooks 2008 on a Windows installation that never had it on there before (virtual machines are handy) and now it works again. I am staying far away from letting it upgrade to latest; that's how my troubles started. I also doubt I will ever shell out money for a more recent version; I upgraded from 2005 to 2008 and it took away the ability to do automatically do IRS 941 forms if you don't pay for monthly payroll services. There has to be better accounting software that doesn't leave users stranded at year-end.
Intuit... | Answered on Jul 23, 2018
http://support.quickbooks.intuit.com/support/Articles/SLN53503
Intuit... | Answered on Jun 19, 2018
1.. Your solution depends on what action you were taking when the error occurred. Please choose the appropriate selection.
You are opening your company file
You are storing your company file on a Windows server
You are storing your company file on a Linux server
You are restoring your company file
2.. Intuit recommends more than one solution for this problem. The first solution may solve your problem, or you may need to try all of them to resolve the issue. For best results, perform the solutions in the order shown.
Solution 1: Change the extension if the restored file extension is .qbm or .qbw.adr instead of .qbw
Solution 2: Check for problems in your file name and file path
3.. You are creating a back up
Create a new File Folder on the root of the C drive.
Create a backup and save it to the newly created File Folder.
for more help visit
QuickBooks Tech Support
Intuit... | Answered on May 24, 2018
what is the phone number at the start of your statement for
Intuit... | Answered on Feb 12, 2018
To make sure you do not encounter PDF issues in the future, always make sure you are on the latest release of QuickBooks. go to this link Unable to reconcile accounts or to create print or email pdf files and follow the steps for under How to fix it for 2010 and older QuickBooks versions only and if need any help follow http://www.techsupportquickbooks.com/intuit/ .
Intuit... | Answered on Jan 03, 2017
Please call quickbooks (844) 414-4868
Intuit... | Answered on Jan 28, 2016
QuickBooks is an accounting software package developed and marketed by Intuit. Quickbooks products are used in small businesses.The online version of the Quickbooks are simpler, faster and easier to use.To use the essentials on online first need to sigh up,after that you can use the software.
Hi John Later,
I understand your Problem but I want tell You Its So long Process for this. we want help to you. you can see all details here :- http://www.securesoftllc.com/ or call :- 1-855-588-6312
24 7 Online Tech Support For QuickBooks
Intuit... | Answered on Jan 27, 2016
Please call quickbooks (844) 414-4868 & have a tech help you so you dont loose sensitive info.
Intuit... | Answered on Dec 15, 2015
check out here put your download query here and search. Downloadanystuff.org/ for refine your search go different category with
your download search query
Only Intuit can generate a validation code.
Intuit... | Answered on Jul 08, 2015
This usually indicates that Windows is damaged. You can reinstall the software, then go to the program files folder, Intuit, Quickbooks 2008 and run the file called Reboot.
Intuit... | Answered on Dec 23, 2014
The program has to be registered.
Intuit... | Answered on Nov 25, 2014
If unable to send your mail from QuickBooks to Outlooks so try for this intuit solution step by step because it is most common issue face by users Error QuickBooks is unable to send your email to Outlook and if need any guidance while configuring then follow Intuit Tech Support for more help.
Intuit... | Answered on Sep 11, 2014
Intuit QuickBooks Pro 2008: Windows Logo
183 questions posted
Top Intuit Computers & Internet Experts
NET MAN
Level 1 Expert
Dalynn Turner
Alun Cox
Are you an Intuit Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
QuickBooks Intuit
  • QuickBooks Intuit
Most Popular Question
change pound sign euro sign
  • Computers & Internet
