Tomtom ONE GPS Receiver Logo
Posted on May 27, 2010
How do you change the am to pm on the tomtomGPS setting
Jerry Manning
Level 1:
New Friend:
  • Contributor 5 Answers
  • Posted on Aug 05, 2010
Jerry Manning
Contributor
Level 1:
New Friend:
Answers
5
Questions
0
Helped
11083
Points
20
Go thru the menu to change preferences, keep scrolling til you find the clock icon. then just press the up or down arrow .
2helpful
2answers
Why does the date on my seiko sne881 change at 12 noon?
probably because you have it set to 12 pm midnight and not 12 noon so at 12 noon it is actually midnight when the date will change
reset the time of the day to am or pm and any pm settings will change the date at 12 midnight.
Model #MWG9111SL
am/pm may not be a separate control. Try setting the hours 12 hours ahead to change from am to pm.
How do I get my clock radio to change to the PM indicator?
you need to set your time to the correct hour... am for am pm for pm. this mean you may need to cycle past the current hour you Think it is and go to the next example you want 3 pm and it is showing 1AM,,, you go past 3 AM all the way to the next 3 which will be 3 pm.
Jvc model av36f702 it jumps of evry time im trying to put it on with the remote . i tink the timer is set to 0 secones .can i reset the tv.
press display button & it shows the following
07
NOW 12:20 PM
SLEEP TIMER OFF/on
ON/OFF TIMER EVERYDAY
ON TIME 7:00 PM
OFF TIME 10:00 PM
• The current channel or AV input (Channel 07)
• The current time (12:20 pm)
• Sleep Timer status/minutes remaining (The Sleep Timer is off)
• On/Off Timer status (Set to turn on everyday at 7:00 PM, off at 10:00 PM)
• Each Press of the DISPLAY button changes the display mode:
Press the SLEEP TIMER button & set it to OFF
1helpful
We have a honeywell cm921 and we cant set the therm astat to come on in the mornijng and then go off then come on again in the afternoon on timer please can you help
Your CM921 has 6 built in temperature settings based on time of day:
1 - 6:30 AM
2 - 8:00 AM
3 - 12:00 PM
4 - 2:00 PM
5 - 4:00 PM
6 - 10:30 PM
meaning that at 6:30 AM the themostat will change its temperature setting to setting 1, at 8:00 AM it will change the temperature setting to setting 2, and so on. To schedule temperature settings which best fit you, determine which time periods you would like more or less heat.
For instance, to fit what you requested in your question you could program a temperature you would like to maintain in the morning and afternoon times when you would like it to be on, and in the time periods in between set a lower temperature as follows:
1 - 20C
2 - 16C
3 - 16C
4 - 20C
5 - 20C
6 - 16C
With this example your thermostat would turn on at 6:30 AM as long as the temperature was below 20C and maintain that temperature until 8:00 AM. At 8 it would change its setting to 16C allowing temperature to drop from 8 AM to 2 PM to a lower setting to conserve energy until afternoon time when the setting would change back to 20C from 2 PM to 10:30 and then change back to 16C to save energy throughout the night. The actual temperatures would be at your discretion based on your individual comfort level.
Pages 5 and 6 of the following link will guide you in setting each of the 6 temperature settings.
http://www.wolseleysbc.co.uk/_STEPData/Assets/Honeywell%20CM921%20Room%20Thermostat.pdf
I hope this helps. Let me know if you have any additional questions.
Motorola Moto Q Phone Help on the Alarm
Go to phone menu
then press time & date settings
press set format
then change its format in 12 HOURS or am/pm
then save it will be change
5helpful
Iluv iMM153 please describe how I change the time from 24 hour
i have the exact same problem, i the picture of the product, it says pm on the side of the display, and its can say pm ont he display !!
1helpful
Watch Setting
When you are setting the hour time on your watch just press the pm key on the keyword next to the number 6. this will change to am or pm.
My time is pm and I want to change it to am
Tap screen, Change Preferences, Right Arrow to side 8 of 8,
tap Set Clock.
Adjust time settings... You need to tap hours 12 hours ahead or backwards to change pm -> am.
Top Tomtom GPS Experts
k24674
Mike Cairns
Mike Cairns
Grand Canyon Tech
Grand Canyon Tech
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
