Feature transfer error is usally self explanatory. This most often means there is a conflict with the game and the operating system you are loading it on. As well can be the hardware does not meet the minimum specs or the OS just compatible. Make sure the disk is spotless and if so could be a bad burn of the game. Try running the disk on another pc to be sure its good.
This solution has helped a lot of people. The cause of the problem has been known already and is explained clearly how to fix the issue on the site link below.
Are you sure that's the correct startup file? Look for setup.exe or right click on Autorun and select run. You should be able to select the install directory if you want.
Teh cd that is supplied tries to load to the F drive. My computer and most do not hav a F drive. I hd to hook up an externial drive that is logged in as f to get the drivers to down load. Once I did that it worked fine.
site link below.
