Each time I shrink an high-quality image in Fireworks to a size I need for my website, the image seems to lose some resolution.
Is it possible to shrink such images in Fireworks without loss of image quality?
If not in Fireworks then how?
Most digital cameras will allow you to select the resolution at which it captures images and/or videos. Some call it "resolution" while some call it "image size" or other similar terms.
The higher the resolution or larger the image size, the larger the file. Many online services restrict the maximum size of image and/or video files they accept. Lowering the resolution or reducing the image size will reduce the size of the files.
Please refer to your camera's documentation. If you still need assistance, please reply to this post and specify the make and model of your camera.
photos that have been already taken before any changes will not be affected after photo setting.Use camera menu or setup to look for RESOLUTION, PHOTO SETUP, IMAGE TYPE,STANDARD OR TYPE on menu to change photo resolution..
Here is a conversion chart for DPI (Dots per inch) to LPI (Lines per inch) or PPI (Pixels per inch)
180 DPI................31 lines/inch or 68 PPI 360 DPI................63 lines/inch or 138 PPI 720 DPI................127 lines/inch or 280 PPI 1440 DPI..............255 lines/inch or 561 PPI 2880 DPI..................510 lines/inch or 1122 PPI
If you plan to enlarge your image, it is better to enlarge it when you're scanning rather than in your application. Each time you modify an image, you lose some quality. Keep in mind when you enlarge a small photo, such as a 35 mm slide or wallet-size photo, you'll need to scan at a high enough resolution to retain your image quality, but not so high that your file size is too large to be efficient. You must manually adjust the resolution (dpi) to maintain the same image quality when you resize your image. For example, if you have a 300 dpi 2 x 2-inch image that you want to enlarge to 4 x 4 (a factor of 200%), increase the Scale setting to 200% or change the resolution to 600 dpi.
one way to do this is shrink it to the size that you want, but then have that image link to the full size image stored somewhere else on the web server.
If you have any questions, please do not hesitate to contact me.
Try using Paint. Open it with it, then go to resize and put in the size needed. either shrink it a percentage or type the pixels in. It works pretty good and keeps quality. Then save it under a different name so original dosn't get lost.
While it is common to down size images without losing picture quality, it is unfortunately not really possible to Increase the size of an image without losing picture quality (As you are currently experiencing)
This is why most digital cameras have such a high resolution, so that they can produce very large images that may be scaled down to the end users requirements.
You will need a photo-editing software in order to shrink the image file. If you have a more high-end photo editing program such as photoshop, you can simply go to image > image size, and then input a lower resolution.
Otherwise, you can shrink it using microsoft paint. Open the image file in paint, then go to the image menu, and select the resize/skew item. Keep in mind that your phone only has a 400x240 resolution, so any photos larger than that will not show any better on your phone. If you took this photo from a handheld camera that is 4 or fewer years old, you'll probably want to shrink the photo to 20-30% of its size. Then, just save the photo as a new file, and make sure you save it as a JPEG in the drop-down save menu, or your phone may not recognize the format.
One approach that works for me is to scan the document at high resolution and then shrink it afterwards. For some reason this seems to result in higher quality than scanning at the final (lower) resolution in many cases. For example I use ACDSee Photo Manager to scan or post process a scan from elsewhere. Within ACDSee there is an option in the jpg output (file save as) dialog for quality versus compression. I set this to default to the highest compression and resave the jpg or convert to jpg if the file did not start out that way. This generally shrinks the file by up to 2x or even 4x without any degradation that I can see. For example the screen capture below went from 39k to 18k after this step with no resolution change. If that is not enough I then perform a resize operation, for example 50% which would further reduce the file size down to a quarter of the input size (the dimensions in each direction would shrink by 50%. Even after shrinking, I find that files lookbetter than if they had simply been scanned at the final resolution.
SHQ1 and HQ are two different levels of compression to make the file smaller. This will have a great impact on the image quality.
Generally on Olympus cameras, this is what those letters mean:
TIFF (highest (best) quality) generally not used. Files are HUGE and takes a long time for the camera to save the image to the card.
SHQ (super high quality) you probably wouldn't be able to tell the difference between this and the TIFF
HQ (high quality) which is lower quality than SHQ
SQ (standard quality) which is lower quality than HQ
SQ1 (standard quality 1) which is lower quality that SQ
SQ2 (standard quality 2) which is lower quality that SQ1
A 2048x1536 only seems large because most people have their monitors set to 800x600 or maybe 1024x768 (that's what I have mine set at).
This will seem to make the image REALLY LARGE! It only seems that way because you have to scroll around to see the image.
If you want to print images, you'll want all the resolution you can get.
If you want to display them on your screen (slide show,WEB page) then you don't need large images. You would just need to resize them down.
However, since you may want to both, getting a camera with a higher resolution gives you the choice to do either. Usually, the higher resolution cameras have better lenses and generally take better pictures.
On my camera (the Oly 2100), I always shoot at the highest resolution and the least amount of compression (SHQ on my camera). This allows me to do almost anything with the image. Nowadays, camera media (smart cards) are fairly cheap, HD's are DIRT cheap and CD-Rs are very cheap.
If the images are "keepers", then I personally would want to start with the best image possible and store the images on CD.
The details for each record mode are as follows:
RAW: RAW data is unprocessed image data in its original state to which white balance, sharpness, contrast, color conversion and other processes have not been applied. CAMEDIA Master can be used to display RAW data and save it in other image formats. A RAW plug-in is also available for Adobe Photoshop which also provides the ability to process images in 32-bit color depth.
TIFF: This is the highest-quality mode. images are saved as uncompressed data, which is the best for printing or image processing on a computer.
SHQ: This is a high quality mode using the JPEG format. Because the compression rate is very low, high quality images can be stored.
HQ: This is a high quality mode using JPEG format, with medium compression. Because the compression rate is higher than SHQ, file sizes are smaller. More images can be saved to a card. The file size can be changed in the 3:2 or Enlarge size mode as well as SHQ.
3:2 Mode: Ordinarily the image aspect ratio is set to 4:3. Due to change the ratio to 3:2, the picture size becomes 2592 x 1728 so that the image can be printed without losing the image borders at a photo lab. 3:2 can be set in the TIFF, SHQ, or HQ mode.
SQ1/SQ2: SQ1 is used for resolutions above 1600 x1200 and SQ2 is used for resolutions below 1600 x1200. For both, you can choose high compression to reduce noise or normal compression to save more images.
