Question about Cell Phones
Change picture resoltion
I have pictures on my blackberry that i tried to download and print but the resolution is way to low and its blurrywhen i print them , is therer any way to change the resolution so i can make 4 x 6 copies
Posted by mttomao on
Anonymous
    New Friend:
  • 20 Answers
While it is common to down size images without losing picture quality, it is unfortunately not really possible to Increase the size of an image without losing picture quality (As you are currently experiencing)
This is why most digital cameras have such a high resolution, so that they can produce very large images that may be scaled down to the end users requirements.
Posted on Jan 04, 2010
In uploading to a website, so that pictures could be printed, a comment states low resolution and the pictures may be blurry when printed. Is there any setting on the camera that I can change that would...
I dont know what resolution your camera is, but make sure you have it set at the highest it can go. The higher the resolution the better quality the picture. I had a 12mp camera but you could set it as low as 4mp which is ok for snaps but if you are uploading or printing then you need to set your camera to a higher resolution if you can. Read your instruction book it should tell you how to configure your settings there. If it is an old camera that cant be changed then maybe its time to invest in a higher mp camera perhaps 8mp 10mp or even 12mp
Oct 04, 2010 | Sony Cyber-shot DSC-S700 Digital Camera
Changing the photo resolution
Go to
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=323&modelid=15262
and download the Advanced User Manual. It will give you instructions on setting the resolution for your pictures.
PowerShot SD850 IS / DIGITAL IXUS 950 IS Camera User Guide Advanced
Apr 14, 2009 | Canon PowerShot SD850 IS Digital Camera
When I email a picture, it is too large to download for some
set the camera for a lower resolution (megapixels). go into yr menu and change for considerable low resolution, make some tries to find which one suite to u better usually 2 or 3 millions megapixels should be fine.
Jan 08, 2009 | Samsung S860 Digital Camera
Canon Rebel EOS - Pictures download read Low Resolution
Canon Digital Rebel cameras let you set the image resolution from small jpegs (low resolution) to large jpegs (high resolution) to RAW (best quality, but require post-processing in your computer before you can print them). It's possible that as you were getting to know your camera you accidentally set the image size and quality to a low setting. Now you just need to change it back!
You make this change in the on-screen menu, under the camera menu (first menu, with a camera icon), first item (Quality). Although Canon no longer has the manual for this camera online, you can see This Review Page for more details on where to change this setting on your camera.
Dec 18, 2008 | Canon Digital Rebel / EOS-300D Digital...
I have a panasonic DMC-Fz8 12x optical zoom camera. How can I adjust the resolution? When I get my pictures developed they are low resolution; you can see the pixels.
Hi!
You need to change the PRINT SIZE and image QUALITY to have have a better picture. Try these:
Press 3049231.jpg then select aa5a871.jpg(Picture Size) . You will be given an option for the number of
pixels - ranges from 0.3 to 7 Megapixel. For better print quality, select 7M.
Next thing that you need to change is the Quality. You need to go back to Menu then 4e59df3.jpg. These are your options for quality:
I hope that helps.
Good luck and have a nice day!
Oct 02, 2008 | Panasonic Cameras
Display date & time on developed pictures
When you say it's displayed on the screen, do you mean while it's in playback mode, it's embedded there?
If not, you will have to put your resoltion in postcard mode and make sure in menu that your date or date/time stamp is turned on.
To get to your resolution settings, turn camera on to shooting mode, hit function/set button and arrow down to the bottom left corner where it will show your resolution (L,M,S, etc) and this is where you will find postcard mode.
This setting is the only one you can use date time stamp and will show up in prints, but only good for 4 x 6 prints, anything larger will not be good resolution, it will be pixelated because it's only enough quality for a small print.
Hope this helps!
Mar 12, 2008 | Canon PowerShot A460 Digital Camera
Labels enlarged
if they are diferent resolutions, ex. you change from 200 dpi to 300 dpi, you need to change something inside the printer like the gears (just reversing the platten roller gear and the the withe gera on the motor) and you are printing on 300 dpi with very small fontes.
Mar 11, 2008 | Zebra Z4Mplus Label Printer
Picture resolution
You can resize either in the computer or in the camera. To resize in the camera go to page 65 of the manual.
http://129.33.22.12/release/DSCP92.pdf
Dec 15, 2007 | Sony Cyber-Shot DSC-P92 Digital Camera
Connecting my LCDTV upto my Computer
Once you connect LCD Monitor to your Laptop! I am assuming your referring to a laptop hookup! Most PC's come with a function key which is labeled FN on your Keyboard next to the Ctl key. It should be in blue Print! You should be able to depress that Key along with I believe F8. this will transfer the image on to your LCD Monitor.
Nov 29, 2007 | Computers & Internet
Adding pictures to my contacts' info.
You have to take the pictures in 72x72 format in order to use them for your contacts image. I finally found this after looking on numerous websites. I tried it and it worked. The bummer thing is that you have to take the pictures that you want to use all over again.
Sep 13, 2007 | LG KG800 Cellular Phone
Cell Phones Logo
48 people viewed this question
Top Cell Phones Experts
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
Are you a Cell Phone Expert? Answer questions, earn points and help others
