Screen shows SD Card Locked. The little switch on the card itself is in unlocked position. New battery. Reformatted the card. Tried everything to no avail. Did run a diagnostic and got ERROR CODE = 000060. Have no Idea what that means, and cant seem to find an error code list for the camera. This is a Moultrie DGS-200 Scout Camera. Somebody help me.
Also, did you reformat the card inside the camera, or while it was in a card reader?
If in a card reader, then you should try it again, while it is in the camera itself.
And the first response to your problem is a good one. Make sure that the switch is actually working. Or try to set it to locked, then see if you can write to it. It may be in a reversed marking situation, where it says unlocked, but it is actually locked.
-a.
SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Take the memory card out of the camera. Move the lock switch on the side of the card to the unlocked position if it is in the locked position. Replace the card carefully without moving that switch.The unlocked position on most SD cards puts the switch towards the end of the card that goes into the camera first.
If that doesn't help, try a different card. The card you are using may have a problem that could require formatting. Copy your photos to another drive first. (Use a drive/photo recovery program on your computer (with the card in an SD card reader). There are some that will attempt to read even a corrupted SD card.) Then reformat the card. If the card can't be reformatted, it may have failed. Check your warranty on the card and see if it will be replaced by the manufacturer.
I have a Stealth Cam Skout 7. The screen displays Loc or Lock. To fix this.. On the side of your SD card there should be a little rectangle that will slide back and forth. Slide it the opposite way to unlock it.
Before you try anything, try using another card. If the problem persists, try the suggestions below.
OK, if the memory card itself is locked, you might
sometimes get this error code. All you need to do is to take out the
memory card and switch the lever on the left side to the unlock.
If
the error is still displayed after you did the above, you might want to
try the card in another camera.
If
the card works in another camera . the problem is with your card reader
in your camera.
If you open you sd slot and look inside with a
sharp light , you should be able to see on the left side of the slot
there is a little copper or spring steel lever switch. This switch work
as follows:
1. When no card is inserted / no write protection ,
the switch is open and thus the protection is off. 2. When locked
card is inserted , the tab is depressed and tells the camera that the
card is lock.
Contrary to popular belief ,the little tab on the
sd card is not an electronic switch and does not physically influence
the card operation itself. If you put a locked card into a camera
without a sd lock switch , you would still be able to use the card
normally.
It is incredible difficult to fix this switch because
of space limitations in the sd card. Look into the sd slot and if you
can see the switch , use a needle to pull the little tab down toward the
base of the camera by about 2mm or until it works being careful not to
bend it.
If this does not resolve your problem , there might be a
short in the switch circuit and the camera will need to be disassembled
to resolve this error. This should cost no more than $50.
Please
feel free to contact me if you need further information
If
If
in your camera.
as follows:
card is lock.
normally.
bend it.
Please
If
If
in your camera.
as follows:
card is lock.
normally.
bend it.
Please
Remove the SD card from the camera. Slide the tiny switch on the side of the card to its other "unlocked" position. Reinsert the card in the camera. But if you've already tried this, see this link for additional things that you can try.
OK,
if the memory card itself is locked, you might sometimes get this error
code. All you need to do is to take out the memory card and switch the
If the error is still displayed after you did the above, you might want to try the card in another camera.
If the card works in another camera . the problem is with your card reader in your camera.
If
you open you sd slot and look inside with a sharp light , you should be
able to see on the left side of the slot there is a little copper or
spring steel lever switch. This switch work as follows:
1. When no card is inserted / no write protection , the switch is open and thus the protection is off. 2. When locked card is inserted , the tab is depressed and tells the camera that the card is lock.
Contrary
to popular belief ,the little tab on the sd card is not an electronic
switch and does not physically influence the card operation itself. If
you put a locked card into a camera without a sd lock switch , you would
still be able to use the card normally.
It is incredible
difficult to fix this switch because of space limitations in the sd
card. Look into the sd slot and if you can see the switch , use a needle
to pull the little tab down toward the base of the camera by about 2mm
or until it works being careful not to bend it.
If this does not
resolve your problem , there might be a short in the switch circuit and
the camera will need to be disassembled to resolve this error. This
Please feel free to contact me if you need further information
thought the cards have a little tab on them so they can be "write protected" it is a little plastic tab on the side of the memory card you slide up and down. I know most SD cards have it, CF cards dont so if its anything besides SD memory its probobly the memory card or some little switch or somthing in the camera that tells the camera when the card is in the "Locked" or "Write protected" mode.
Looking at my SD memory cards they have a little arrow on the edge and they say "Lock" pointing down, the slider is up. Move yours both ways, maybe it has a bad connection in the card (im not sure what it actualy does) or its in a position the camera thinks its locked?
