My bike runs rough idleing and at slow speeds. It also is jerking at slow speeds. At full throttle it seems to run fine.
Here is the common cause of surges, cold stalls, stalls at stops, slow idle speed, erratic idle speed, rough idle and engine hesitation (and other problems), it is in most cases the idle speed control air-bypass valve and or throttle valve and upper intake, these area's get full of gunk and combustion residue over the miles and cause idle issues (stalls, low idle) like yours.
To correct this problem Buy a can of throttle valve cleaner (it is made by CRC) from the local auto parts store, NEVER USE CARB CLEANING SPRAY, IT DESTROYS THE ANTI-STICK TEFLON COATING, spray it into the air intake through the throttle body of the engine until you have used about half the can, you will need to hold the idle up while you do this, it will try to stall, after this shut the engine down and disconnect the Negative (-) battery cable for 5 minutes. The intake is now clean, if you continue to have the idle speed control problems you may need to seek the help of a professional.
Throttle Body Cleaning on vehicles without electronic throttle control (most 2003 and down)
You can in most cases repair this slow speed stall or unstable idle by cleaning the engine throttle valve and the idle speed control valve using a product called CRC Spray Throttle valve cleaner. Spray the cleaner into the air intake of the engine with the hose removed from the throttle body, the engine will try to stall so hold up the idle speed manually. Once you have used up about 1/2 can of the cleaner stall the engine out while spraying and turn the key off, disconnect the negative battery cable for 5 minutes and then reconnect and drive the car for a about 25 miles of varied driving modes. If this doesn't cure the problem you may need the fuel injectors professionally cleaned by the dealer service dept.
