Nikon Coolpix 8700 Digital Camera Logo
Posted on Mar 30, 2008
Transfer program Is it possible to get a new CD to work with Vista?
JGjo
Level 1:
  • Contributor 1 Answer
  • Posted on Jun 17, 2008
JGjo
Contributor
Level 1:
Answers
Questions
Helped
23
Points
No. I heard the 8700 isn't compatible with Vista.
2helpful
4answers
Transfer XP files to Vista: i am having a nightmare of a time trying to transfer files from my XP computer to my new Vista computer. I tried using an Easy Transfer Cable fo Windows Vista. The driver CD was...
yeah u can use remote desktop connection.which u can find in start->program->accessories->remote desktop.first u need to connect the two computers using lan wire(ethernet cable)....for detailed help ask me on [email protected]
Need software for Zire M150 that runs on Windows Vista?
Older palm products and vista aren't compatible. You either needs to transfer info via bluetooth or upgrade your palm if you wish to continue using vista. As far as transferring, possibly a memory card.
3answers
How to import Outlook Express mails to Windows
Open Outlook Express go to File then Export and proceed to what you want to export. Follow the instructions from there. You will need a flash drive or CD to save the files and move them.
Next go to Windows Mail, go to File then "Import".
Follow the instructions and you should be good!
My transfer disc is not copying on to my new computer.
if one way to solve this. just u do that you remove the harddisk from your old computer.
and connect in your new model(just remove ur cd drive cable then only you can connect the harddisk).
if u want to copy old files from your cd to computer. use isobuster1.1ver. but if all your old software
are not possible to on a vista
I need to transfer files from an old computer using Windows 2000 pro to a new computer runing Vista. The problem is that I cannot get my old computer to do a backup to my cd or to an external device.
When you upgrade to Windows Vista, you can use Windows Easy Transfer to transfer files and settings from a Microsoft Windows-based computer to the Windows Vista-based computer. When you use Windows Easy Transfer, you can decide what to transfer to Windows Vista. You can also select the transfer method that you want to use. See Microsoft's article on the subject at
http://support.microsoft.com/kb/928635
I am using pc to pc file transfer for dummies I know how to hook it to both computers but I have no idea how to drag files I have windows vista
Windows Easy Transfer is installed with Vista and can be found under Accessories - System Tools or by searching for "easy" (with out quotes).
You can transfer files and settings using a network share, or transfer files and settings using removable media such as CD/DVD, or an external hard drive.
Windows Easy Transfer does not migrate installed applications (see Windows Easy Companion below)
Using Windows Easy Transfer, you can migrate most files and program settings. Below is a table describing the types of data and settings that can be moved.
Data Type Specifics Files and Folders Any files found in My Documents, My Pictures, and Shared Documents folder will be selected to be moved automatically. You can also add other documents that are in other locations. E-mail messages and Settings E-mail messages, contacts, account settings, and address books from Outlook Express, Outlook, Windows Mail, and other programs. Program Settings Programs that are compatible with Vista will have their settings transferred to the new Computer. In order for this to work the program must already be installed on the Computer running Vista. User Settings Desktop settings, color settings, screen savers, fonts, Windows options, printers, etc. Internet Settings Favorites, cookies, and Internet Explorer settings. Pictures, Video, and Music Music files, playlists, and album. Pictures (gif, jpg, bmp files) and personal videos.
Please don't forgert to rate this.....
Bernina bernette deco 600 - Vista
If your deco wizard is the same as the pe-design 2,3,4 you can transfer your designs to the computer in the file utility, then you can save them to usb and transfer to your Vista computer.
Software Required
You can run that same disk on Windows Vista. When you put it in, the computer will tell you that it won't work with this OS. It then gives you a possibility were you can create a virtual state where windows vista manipulates the program. So the program then thinks it's running on WINDOWS XP but you can install it on your vista.
Vista programs that work and don't work
List of compatible hardware and software
Some of your XP programs may need to be upgraded to work with Vista.
Copy files from old computer and transfer to new computer
Although Vista comes with an Easy File Transfer Wizard it is not compatible with Windows 98.
You will need a CD burning program such as Nero Burning Suite or Creative CD Writer or here is a link to a FREE one.
Top Nikon Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Nikon Camera Expert? Answer questions, earn points and help others
