Below I listed 3 reasons why this may be happening and a product that will clean this off for you!
Glasses Are Cloudy/Spotted:
• Select Extra Rinse (select models).
• Check water temperature. Incoming water should be 120°-140° F (49-60° C).
• Always use a rinse aid.
• Confirm that the cloudiness is removable by soaking the item in white vinegar for approximately 5 minutes. If removed, the problem is due
to hard water. Adjust detergent amount being used to match water hardness (pg. 5). Be sure detergent is fresh, stored properly and is a
high quality brand.
• If cloudiness is not removable, it is etching. This is an erosion of the surface of the glassware and can be caused by water that is too hot,
from using too much detergent or by prewashing. Detergent needs food soil to act upon. If etching has occurred, the glassware is permanently
damaged. To prevent further etching, adjust the detergent amount to match the water hardness, stop prewashing, and be sure incoming
water temperature temperature is not greater than 140° F (60° C). Use water heating options only when incoming water temperature is below
120° F
Food Soil Remains on Dishes:
• Run hot water at the sink before starting the dishwasher.
• Select Tough Scrub™ or Tough Scrub™ Plus (select models).
• Check water hardness and adjust detergent amount accordingly
• Use fresh detergent stored in a cool dry place.
• Select proper cycle for the soil level.
• Load items so they do not block the wash arms or center tower
• Load the utensil basket with some handles up and some down to prevent nesting.
• Do not place glasses over tines.
• Prior to loading, scrape off burnt on foods and wipe the starchy film from utensils used with pasta, rice and oatmeal. These soils require
more energy than the rest of the load to clean.
Items Washed In The Dishwasher Or The Dishwasher Tub Itself Are Stained/Discolored:
• Aluminum utensils or pans can leave marks when they rub against other items. Leave a slight space between items.
• Iron deposits in the water can leave a yellow, brown or orange film on dishes or the dishwasher tub. A filter may be needed, check with a
water treatment company. RoVer Rust Remover (part no. 057961)** can be used to remove rust. Do not use RoVer along with dishwasher
detergent. Fill both cups with RoVer and complete a Normal Wash cycle. Follow with a short wash cycle using dishwasher detergent.
• Color from tomato sauces may adhere to the tub . If light staining has occurred, leave the door open to oxidize the stain away. For
removal of heavier stains, try a citric acid containing dishwasher cleaning product such as Glisten (part no. 18001017)**. Change dishwasher
detergent and be sure to use a dishwasher detergent that contains chlorine to better fight staining.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
The scum, film and white
residue problems have started since the reduction of
phosphates in dishwasher detergents.
Here is a tip that
will help you to solve the problem of films, residue, and scum in
your dishwasher.
Dishwasher
Residue and Film on Dishes
heatman101
I haven't tried the solutions yet, but there is a lot of information here to work with. Thank you!
The problem is hard water. www.dishwasherfilter.com has a product to solve this problem once and for all. It filters the water going into your dishwasher and removes the hard minerals that leave those spots. It is very affordable and even has a money back guarantee. You will love the way your dishes look with this product.
