try this solution from microsoft:
I can’t play a file that Windows Media Player supports. What should I do?Most
likely, a required codec isn't installed on your computer. Typically,
Windows Media Player automatically downloads any required codecs from
the Internet and installs them. However, this may not happen for the
following reasons:
The necessary codec (typically, a non-Microsoft codec) isn't available on the codec server.
You have an older version of the Player and your automatic codec-download option isn't enabled.
The Internet security settings for your browser are set too high.
You're not connected to the Internet.
If
you have an older version of the Player (prior to Windows Media Player
9 Series), you can check your codec download setting by doing the
following:
1.
In Windows Media Player, on the
Tools menu, click
Options, and then click the
Player tab.
2.
In the
Auto upgrade area, make sure
Enable automatic codec download is checked, and specify how often you want the Player to check for updates.
You
can change your Internet security settings (if you are logged on as an
administrator or a member of the Administrators group) by doing the
following:
1.
In Control Panel, open Internet Options.
2.
Click the
Security tab, and then click
Internet.
3.
In the
Security level for this zone area, click
Default Level.
If you can’t play the file after completing this procedure, restart your computer, and then try to play the file again.
If
you still can’t play the file, try to play another file with the same
file name extension. If you can play this file, then there is a problem
with the file that you want to play. For more troubleshooting
information, see the
Windows Media Player Multimedia File Formats Web
