Garden Logo
Anonymous Posted on May 09, 2010
I am trying to get the manual for Hyundai
I am trying to get the manual for Hyundai Cordless Lawn Mower SPL-CLM-8 Mulching Mower 9" it is 36 volts/ Please I have paid and tried for hours and I keep getting chain saw results. It is a lawn Mower for cutting Grass, Lawns Please reply and tell me how to get the manual [email protected]
Anonymous
Level 2:
New Friend:
  • Expert 61 Answers
  • Posted on May 09, 2010
Anonymous
Expert
Level 2:
New Friend:
Answers
61
Questions
0
Helped
51072
Points
114
On your computer, type in the search box
Hyundai/manual, you should be able to get it from there
2helpful
2answers
B&D 19” cordless mower. Why are wheels falling off?
Use locktite red on the threads. It may also be that one bolt is left hand thread and the other side is standard right hand thread. The should be on so that moving forward tightens the nut. You should also have two washers and a nut. I wonder if you have the one that was discontinued?
36V 19" Electric Self-Propelled Lawn Mower - Black & Decker
www.blackanddecker.ca > lawn-mowers > spcm1936
Mow up to ? of an acre with the removable BLACK+DECKER 36V mower battery. Have a larger lawn? 36V cordless technology allows you to charge additional ...
Black and Decker Lawn Mower Parts ' Fast Shipping ...
www.ereplacementparts.com > black-and-decker-lawn-...
Black and Decker Lawn Mower parts that fit, straight from the manufacturer. Use our ... 37052 Type 1 Black and Decker 19 Crafts Cordless Mower Parts.
Rechargeable Battery Powered Mower - Black & Decker
www.blackanddecker.com > lawn > lawn-mowers > 36...
36V 19 in. Mulching/Bagging Mower. This product has been discontinued and replaced with ... Adjust the height of all four wheels at once with the pull of a lever.
May 12, 2020 • Garden
How to use mulch plug on cordless mower
Mulch plugs are typically a cover that is affixed to the discharge chute of a mower deck. As blades spin, they cut grass, and lift them up into the swirling air above the cut grass and below the mower deck. The clippings are suspended until they are blown out of the chute.
Mulching, is the process where grass clippings aren't simply discharged out of the chute after cutting; rather they are kept under the mower deck and spin around suspended in the blades resulting in repeatedly being cut. Instead of long clippings exiting the chute, much smaller clipping result from multiple cuttings and settle back on to the lawn under the deck. The smaller clipping allows them to decompose much quicker and return nutrients to the lawn.
Long clippings take longer to decompose and can turn into thatch on top of soil between blades of grass - effectively smothering the lawn. Long clippings can sit on top of cut grass and choke off sunlight, etc. and cause dead spots. Thatch can occur with mulching too - but takes longer to accumulate.
I nearly always mulch
Apr 17, 2015 • Worx Garden
This is my second mower. First one damaged after hitting a rock. My replacement mower will not discharge grass out of the side discharge. I have the mulching attachment in and the discharge chute as...
it could be a low lift blade on it. try to get gator blade for mulching..... or a high lift blade. lol, size does matter!!! this may fix the issue. there is so many blades out there now, experiment till you find what your looking 4......
Short battery charge
The B & D MM575 mower is not battery operated nor is it cordless. CMM1200 CMM1936 CMM1836 are the currently available cordless mowers. You can buy a battery from B &D, they list it here:
http://blackanddecker.com/ProductGuide/Product-Details.aspx?ProductID=22989
tom
3helpful
2answers
I would like to buy a petrol lawn mower, i have found out there are mulching lawn mowers on the market, what are your views on this type of mower
Mulching mowers are great if you dont have the time to rake the excess grass or the means ( time or ability) to dispose of te collected remains. The mower will mulch te grass right back over te top of the cut grass with minimal apperance of grass being left behind, if you kep up on the cutting schedule that is. Better for larger areas where "lines" would usually remaine with a non mulching mower.
23helpful
4answers
Replacement batterys for cmm1200 black&decker electric mower
You can find replacement batteries on amazon, click here and take a look: Amazon com Black and Decker 24 0 Volt Lawn Mower Battery 90508011. I hope this was helpful. Cheers
Top Garden Experts
Jay Finke
Jay Finke
john h
