I want to funish the Catcher (bag) for this mm525 3.5HP type 2-12 black&decker Lawn Mower...
(More)
I want to funish the Catcher (bag) for this mm525 3.5HP type 2-12 black&decker Lawn Mower please. TBOrange@comcast.net
Thanks to you guys I figured out how to wire up the switch, but the wires were all disconnected on...
(More)
Thanks to you guys I figured out how to wire up the switch, but the wires were all disconnected on the rectifier as well when I found it. Can anyone take a picture or draw a sketch of how it is supposed to be wired up? AC x ___ | ___ ___ - AC Thank you all Hugo
The breaker (Short Stop 24v F09 40A) is faulty. I got a replacement but when it arrived I findit is...
(More)
The breaker (Short Stop 24v F09 40A) is faulty. I got a replacement but when it arrived I findit is a short stop 12v s28 40A. Can this be used and if not where can a 24v 40A be purchesed A spare board costs over $300 !!!!
I have a Black&Decker cordless mower. Model CMM 1200. When I plug in the wall mounted...
(More)
I have a Black&Decker cordless mower. Model CMM 1200. When I plug in the wall mounted charging unit the green light is already on. The mower was last used about 1 month ago and is not charged. Replacing the wall charger should be no problem but want to replace internal battery (I assume there is one). Where is it and is it easy to do?
I have19 inch CORDLESS mulching rear bag mower from black and decker.The spring on the on -off lever...
(More)
I have19 inch CORDLESS mulching rear bag mower from black and decker.The spring on the on -off lever switch fell off .I need some help in getting it back on. Thank you.
The pin on the starting switch broke into three pieces. one piece is still stuck in one side of the...
(More)
The pin on the starting switch broke into three pieces. one piece is still stuck in one side of the casing. even if I had the pin I am not sure how to put it back on. I do not know were the spring in the handle attaches to.. Do you have any diagrams that would help. Gary Northey.
Precise Engine Repair proudly represents Briggs & Str... Read More
Precise Engine Repair proudly represents Briggs & Stratton, Honda, Kohler, Tecumseh, Onan engines and Drainzit oil drain systems. Our goal is to offer free information, along with giving you an outlet to buy genuine original equipment manufacturer (OEM) parts at a discount.
