HI!, I had met the headache things that I had forgotten Windows login password. The login screen rejected my passwords. I was frustrated because there was very important data on my disk and I couldn't reinstall the OS. ............. However, I fortunately got to know the Windows Password Recovery Tools below .
1. Windows Password Recovery Tool 3.0( http://www.windowspasswordsrecovery.com )
2. Windows Password Key 8.0( http://www.lostwindowspassword.com )
3. Windows Password Recovery 6.0( http://www.recoverlostpassword.com/products/windowspasswordrecoery.html )
4. Any Windows Password Reset 7 ( http://www.windowspasswordreset.net )
5. Windows 7 Password ( http://www.windows7password.net )
6. windows password cracker ( http://www.windowspasswordcracker.com )
I compare these tools and try the first one, it help me to recover my forgotten windows xp password in only five minutes.
1.you can go into safe mode (F8 at logo when booting up) and enter as administrator and then go to accounts and change windows password and that's with XP. I haven't forgotten password for a pc before but can enter any XP pc in safe if the owner hasn't gone into safe mode and designated a password for "administrator" and usually only have a password for the user account but never have tried on Vista or Win7.
2.if that does not work,you can use software to reset the windows password I know a windows password tool just like below Windows Password Key 8.0 http://www.lostwindowspassword.com
Possible fixes
Mouse Keys can be enabled a number of different ways. The setting could have been activated while syncing from a MobileMe account that had the preference enabled, migrating a user from another computer using Migration Assistant that had the preference enabled, or by pressing the Option key five times (if that setting is enabled in System Preferences).
To check your System Preference settings, or to enable/disable Mouse Keys:
1. Open System Preferences and click on the Universal Access preference pane.
2. Click the Mouse & Trackpad settings tab.
3. Click the "Off" radio button next to Mouse Keys.Note: You may also check/uncheck the box for "Press Option key five times to turn Mouse Keys on or off".
Note: If you are logged on to a user where Mouse Keys is already disabled, but your keyboard is not responding properly, toggle the radio buttons for Mouse Keys "On" then "Off" to restore normal functionality.
Other Method to reset Admin Password.Start up from a Mac OS X Install disc (one whose version is closest to the version of Mac OS X installed). Usually, you can start from the disc by putting it in your computer, restarting, and holding the C key. Or, put it in the computer and click the Install or Restore icon you see in the disc's main window (after which the computer will start from the disc without you needing to hold C). Or, you can use Startup Manager or the Startup Disk preference pane to select the Install disc.
Choose a language, click the arrow button to continue,
Mac OS X v10.6 or later: Choose Password Reset from the Utilities menu.
Mac OS X v10.5 or v10.4: Choose Reset Password from the Utilities menu.
Mac OS X v10.3: Choose Reset Password from the Installer menu.
Tip: If you don't see this menu or menu choice, you're probably not started from the disc yet.
Note: The default keyboard layout is U.S. English while started from the installation disc. If you use a keyboard layout other than U.S English, use the Input menu (the flag icon on the right side of the menu bar) to select the desired layout before typing a new password.
Select your Mac OS X hard disk volume.
Select the user name of your original administrator account.
When you boot up to the log in screen type in administrator as user to log in if you cant log in
during the boot up process you will see on the screen for a short amount of time press a certain key to enter set up press and hold that key during the boot up process to enter BIOS using the arrow keys scroll down to set user password or supervisor password you can change or remove your password from there
also
The most common way that we know on how to reset or clear the BIOS password is to physically remove the power from the computer by disconnecting the power plug and then removing the Cmos battery for 30 minutes from the motherboard. Another way is to reset the clear CMOS jumper on the motherboard itself.
Both of the 2 methods mentioned works because most motherboards use a battery to sustain the BIOS/CMOS settings for the motherboards PROM chip. So by cutting off cmos the battery power, the BIOS/CMOS settings will be erased.
cmos battery Under the keyboard or bottom of laptop - If you are working on a laptop computer the location of the dipswitch (almost never a jumper) can be under the keyboard or on the bottom of the laptop in a compartment such as the memory compartment. Although on some motherboards the Cmos battery is soldered in
Often many users will leave the administrator account alone or have other accounts with administrator rights. If you're not logging into the computer as administrator or have other accounts follow the below steps to reset your other accounts password.
Reboot the computer into Safe Mode
When logging into Safe Mode you should be prompted with an option to what account you wish to use. Select the Administrator account. If prompted for a password try pressing Enter on the keyboard for no password. If this does not work, try other passwords you may have used. If you're unable to log into the Administrator account skip to the next suggestion.
Once you've logged into the Administrator account open Control Panel and User Accounts.
also
The most common way that we know on how to reset or clear the BIOS password is to physically remove the power from the computer by disconnecting the power plug and then removing the Cmos battery for 30 minutes from the motherboard. Another way is to reset the clear CMOS jumper on the motherboard itself. Both of the 2 methods mentioned works because most motherboards use a battery to sustain the BIOS/CMOS settings for the motherboards PROM chip. So by cutting off cmos the battery power, the BIOS/CMOS settings will be erased.
cmos battery Under the keyboard or bottom of laptop - If you are working on a laptop computer the location of the dipswitch (almost never a jumper) can be under the keyboard or on the bottom of the laptop in a compartment such as the memory compartment. Although on some motherboards the Cmos battery is soldered in Often many users will leave the administrator account alone or have other accounts with administrator rights. If you're not logging into the computer as administrator or have other accounts follow the below steps to reset your other accounts password.
what operating system ? and what type and brand of computer desktop laptop ?
Reboot the computer into Safe Mode.
In User Accounts select the account you wish to change the password for, click change password and then enter the new password or click remove the password to remove the password from the account.
hope this helps
When you boot up to the log in screen type in administrator as the user to log in once you have your computer running again you have to take control (administrator)control panel user accounts on the users tab,click the name of the computer administrator you can change the password there or if your computer has a system restore you can restore it to an earlier date which will have your personal settings Remove a small coin sized CMOS battery to store all BIOS settings along with the password. To reset the password, unplug the PC, open the cabinet and remove the CMOS battery for approx. 15-30 minutes and then put it back. It'll reset all BIOS settings as well as the password and you'll need to re-enter all settings. Under the keyboard or bottom of laptop - If you are working on a laptop computerthe location of the dipswitch (almost never a jumper) can be under the keyboard or on the bottom of the laptop in a compartment such as the memory compartment. If it fails, then try to remove the battery for at least one hour. click start control panel Open User Accounts in Control Panel. On the Users tab, click the name of the user whose password you want to change, and then click Reset Password. In New password and Confirm new password, type the new password, and then click OK. Notes You can change passwords only for local computer accounts, such as guest, administrator, or accounts you create for your computer. You cannot change your network logon password in User Accounts. To change your own password, press CTRL ALT DELETE and then click Change Password or You need to prepare: hope it helps. don
or if you still cant get past this password
1:A blank CD/DVD or USB flash drive
2.A computer which can link to internet
3.A program called Windows Password Recovery 6.0
Get started with this 3 simple steps:
Website: http://lost-password.net/products/windowspasswordrecoery.html
Step 1 - Download windows password recovery utility and install it.
Step 2 -Burn your Windows Password Reset CD:
To burn your CD, you'll need a blank CD-R and the .ISO file of Windows Password Reset.
Step 3 - Put in your newly created CD and remove your Windows password.
don't forget to vote
if you did not make yourself the administrator of your computer When you boot up to the log in screen type in administrator as the user to log in once you have your computer running again you have to take control (administrator)control panel user accounts on the users tab,click the name of the computer administrator you can change the password there or if your computer has a system restore you can restore it to an earlier date which will have your personal settings also you might try during the boot up process you will see on the screen for a short amount of time press a certain key to enter set up Press and hold that key during the boot up process to enter BIOS scroll down to set user password or supervisor password you can change or remove your password from there also click start control panel user accounts on the users tab,click the name of the computer administrator you can change the password there if you still cant get into your computer
Ebay you can purchase a
Password Unlock/Recovery For Windows 2000/XP/Vista/7
Item title Password Unlock/Recovery For Windows 2000/XP/Vista/7
Buy It Now price: US $1.49 (Approximately AU $1.50)
hope this helps
hope this helps
first make sure the caps lock if off/on whatever applies the password when you typed it in
hope this helps
the administrator if she has not made herself the administrator
click start control panel user accounts on the users tab,click the name of the computer administrator you can make yourself the administrator of your computer there which will give you all rights to change whatever you want on this computer
or
also
hope this helps
the administrator if she has not made herself the administrator during the boot up process you will see on the screen for a short amount of time press a certain key to enter set up Press and hold that key during the boot up process to enter BIOS scroll down to set user password or supervisor password you can change or remove your password from there also
or
hope this helps
