According to the teen,, PC would not turn on anymore.. Replaced power supply with new and same thing.. Green light on the M-Board but nothing else.. Thx
Unplug every thing except /PS,CPU,and turn on
If CPU fans are running,and you do not hear any beeps
,it is most likely a fried motherboard
Hey there sourmug, could you ask the teen what they were doing when the machine stopped working and what exactly happened. Also have you looked on the board for any bulging capacitors, either near the cpu or the Ram. Also I would pull the ram and inspect it for signs of extreme heat. If it looks fine, replace and ensure it is correctly seated. My best guess at this stage is that the ram is your problem, however more info would be helpful.
Check the ram and make sure is securly in it's place.. Unplug everything else from the mobo except power and fan/cpu and power button..
Do the fans come on?
MACHINE WOULD NOT START UP. CHANGED POWER SUPPLY SAW GREEN LIGHT ON MOTHER BOARD, FAN STARTED AND STOPPED AND NOTHING ELSE HAPPENED
