20 Most Recent
Microsoft Windows XP Professional SP2 Full Version OEM for PC (E8504026) Questions & Answers
I want to change Product key for windows xp
You can download a program called WinXP Manager. you can do a number of tweaks including changing your product key.
However it is not free, but you can download the free trial version.
Regards
4/6/2016 5:38:33 AM •
Microsoft...
Answered
on Apr 06, 2016
Windows xp
Get a hold of any Windows XP Home or Professional (depending on which you have on your computer) and BOOT the computer with that CD. (make sure you have you PRODUCT KEY ready - should be on a sticker somewhere on your computer) The startup of that CD will stop at a screen that offers you to REPAIR etc.... DONT do a "repair" there. Choose "continue" .... It will get to anotrher screen that wants you to press F8 to accept the rules etc of Microsoft. After you have pressed F8 you will get another screen that offersw REPAIR or clean install etc.... Press "R" to repair. It will search for an installed version of your windows... When it shows a windows installation you should Accept that one and press eiter "R" or "enter" or "continue" (whatever it asks you at that stage) ...
The computer will then continue to replace faulty files etc and FIX your installation. It will at some stage ask for your Product Key. t will then go through and complete the installation. It may also (after the installation) want you to ACTIVATE the windows installation which you can then do ONLINE or via telephone.
The above repair installation will be possible
only if your hard drive is OK. If not the installation would either not happen or will crash halfway through
8/25/2015 3:07:29 AM •
Microsoft...
Answered
on Aug 25, 2015
How do i uninstall google chrome?
you have got two waysgoto 1.start menu 2.select google chrome 3 select uninstall google chromesecond methodgoto control panel,add or remove programs and select google chrome and press ok to uninstall
5/8/2012 5:10:09 PM •
Microsoft...
Answered
on May 08, 2012
I cant install manual cursor
First off I would not install cursor mania because it opens holes in the security of your computer and will let in many different bugs and viruses. but if you really want to install it, try closing out your browser and rebooting your PC, then try and install. if this doesn't work make sure you are using the latest version of Internet Explorer, then try again.
3/4/2011 7:16:40 AM •
Microsoft...
Answered
on Mar 04, 2011
Error 800A0408
run chkdsk/f which will automatically fix any corrupt files you may have to fix your registry
hope this helps good luck
9/6/2010 3:45:33 AM •
Microsoft...
Answered
on Sep 06, 2010
Just defragmented my computer and Norton System
sforrest_dou
Even if you ran the defrag program you may still not get a full defrag because your disk space it to low.
To get a go defrag you have to have 15% or more free space to get a good defrag of your hard drive.
Let me know if you have any more problems or questions
Issken
http://www.fixya.com/users/issken
7/17/2010 7:08:07 PM •
Microsoft...
Answered
on Jul 17, 2010
Unable to format pendrive due to viruses.
you have to stop
Autorun feature of yourwindows which kicks in when we connect any new storage device first,then you will be able to format the drive and start fresh.
Steps to remove autorun:
http://support.microsoft.com/kb/967715(restart your computer first without the pen drive and then start the below procedure)
- Click Start, click Run, type regedit in the Open box, and then click OK.
- Locate and then click the following entry in the registry: HKEY_CURRENT_USERSOFTWAREMicrosoftWindowsCurrentVersionpoliciesExplorerNoDriveTypeAutorun
- Right-click NoDriveTypeAutoRun, and then click Modify.
- In the Value data box, type 0xFF todisable all types of drives. Or, to selectively disable specificdrives, use a different value as described in the "How to selectivelydisable specific Autorun features" section.
- Click OK, and then exit Registry Editor.
- Restart the computer.
12/5/2009 10:37:58 PM •
Microsoft...
Answered
on Dec 05, 2009
Iam unable to access my taskmanager
If you can only boot the system in Safe Mode try running a system restore back to
a point before the problem this may allow you to temporarily access the system.
At this point since the system is fairly new maybe you don't have tons of stuff loaded
I recommended that you do a clean install on the system As far as the system not
being protrected this is the first thing that you should do before adding programs on the system.
I hope that this has been very helpful for you
11/28/2009 3:13:04 PM •
Microsoft...
Answered
on Nov 28, 2009
I have windows xp professional and when I run my
If you get the error-message when you try to boot your computer, your disk-drive is either:
1. not connected to the motherboard
2. improperly connected to the motherboard
3. dead/dying, so that the Operating System files on the disk-drive *CANNOT* be read.
So, the computer tries to boot from an "alternative" device (either the 3.5-inch device or the CD-ROM device) -- if you don't have any media inserted into either device, you will get the error-message.
10/26/2009 12:01:38 AM •
Microsoft...
Answered
on Oct 26, 2009
I want to open my windows xp professional sp2.but
As this is an original, Microsoft will class it as simply a lost licence key.
Phone you local Microsoft branch and explain you have lost your key. They will ask you a couple of easy questions about the disk and then supply you with a new key that is fully functional. You will then be up and running.
If this helped you then please help me by voting kindly.
10/13/2009 8:31:37 AM •
Microsoft...
Answered
on Oct 13, 2009
I need a windows xp 2002 product key
The product key should be on the case for the cd. If you lost the case go to support.microsoft.com and you can get a new code. You can not purchase XP anymore unless a store still has one because Micrasoft discontinued making XP and replaced it with Vista.
9/27/2009 3:43:35 PM •
Microsoft...
Answered
on Sep 27, 2009
Error code LP5
This error code only comes when the software is not properly downloaded. Try re-downloading.
Thank you.
9/23/2009 12:19:30 PM •
Microsoft...
Answered
on Sep 23, 2009
