Jet 3 Ultra Power Chair Logo
Posted on Apr 30, 2010
While charging batteries in what position do the levers for locking the chairs wheels go
Anonymous
Level 1:
Problem Solver:
  • Contributor 6 Answers
  • Posted on May 13, 2010
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
6
Questions
0
Helped
4609
Points
11
You don't need to "lock" anything. While charging, the joystick is locked out already.
Jet7 power chair flashing red and yellow lights and not staying charged but a few hours at a time, had battery check, said they were ok. help
Hi June,
Any electromechanical device requires occasional troubleshooting. However, most problems that arise can usually be solved with a bit of thought and common sense. Many of these problems occur because the batteries are not fully charged or because the batteries are worn down and can no longer hold a charge. Below are a series of basic troubleshooting instructions for the Jet 7 Power Chair. This information is to be used as a supplement to the troubleshooting instructions provided in the owner's manual. If you have any questions about this information, contact your authorized Pride Provider. What if the systems on my Jet 7 seem to be "dead" (controller does not light up when the on/off key is pressed)? ! Make sure the batteries are wired properly-refer to the battery wiring diagram located on the power base. ! Make sure the connections on the battery terminals are tight and secure. ! Make sure the battery quick-disconnect harness connections are fully joined. ! Make sure the main circuit breaker has not tripped-push in the main circuit breaker reset button. ! Make sure the controller is completely connected to the power base. What if the range per charge of my Jet 7 diminishes over time? ! Determine if the batteries have ever been replaced. Batteries over a year old may be defective. ! Determine how frequently you charge the batteries in comparison to how often you use the power chair. If you use your power chair on a daily basis, you should charge the batteries every day for 8-14 hours. ! Determine when the batteries were last charged. Even if the power chair has not been in use, the batteries should be charged once a week for 12-14 hours. ! Determine how long you let the batteries charge. It takes 8-14 hours to fully charge a depleted set of batteries; continual undercharging reduces the overall life of the batteries. ! Observe the ammeter during battery charging to determine if the batteries are receiving a charge. If the ammeter does not go up when the battery charger is plugged into the charger power cord receptacle and an electrical outlet, the batteries are not getting charged. Check the charger fuse and ensure the electrical outlet is good. ! Determine if a wall switch controls the electrical outlet used for battery charging. If a wall switch does control the outlet and the switch is turned off inadvertently, the batteries will not fully charge. ! Is an extension cord being used to connect the battery charger to the electrical outlet? Pride prohibits the use of an extension cord when charging the batteries. The charger should be plugged directly into a properlywired standard electrical outlet as the length and condition of the extension cord can have an adverse affect on the battery charger. ! Determine how far you let the battery condition meter LEDs go down before charging the batteries. If you continually allow the battery condition meter LEDs to fall into the red area, the overall life of the batteries will be reduced. What if my Jet 7 is operating slower than it has in the past? ! Determine when the batteries were last charged. When the battery charge gets low, the batteries supply less power to the motors, which causes the motors to spin slower. ! Determine the temperature of the power chair at the time the problem occurred. The Jet 7 electrical system will protect itself from overheating when its internal temperature gets too high by reducing the amount of power sent to the motors. When this happens, the power chair will gradually slow to a stop. Allow the power chair to cool down and it will resume normal operation.
What if my Jet 7 begins pulling to one side? ! Determine if the joystick is being deflected straight or at a slight angle. Even a small amount of deflection right or left will cause the chair to veer over a long distance. ! Determine if both manual freewheel levers are in the drive position. If only one manual freewheel lever is in the drive position, the other motor will not operate and the Jet 7 will veer severely. ! Determine if both tires are inflated to the proper psi if the power chair is equipped with pneumatic tires. Pneumatic tires should be inflated to 35 psi (2.4 bar). If one tire is inflated more than the other, the power chair will pull to the side that is underinflated. ! Determine if the caster wheels are pivoting freely. If either caster wheel is not pivoting freely, the unit will veer to the side. What if the Jet 7 powers up, but will not move? ! Determine if both manual freewheel levers are in the freewheel position. If the power chair is in freewheel mode, then the electronics will function but the motors will not spin the wheels. ! Determine if the controller is flashing a fault code. The Jet 7 comes equipped with a VSI controller. The VSI controller will flash a code via the battery condition meter LEDs if a system fault is detected.
# OF LEDS CODE CAUSE POSSIBLE SOLUTION One red LED 1 Low battery voltage Charge batteries Two red LEDs 2 Left motor open Make sure left motor is plugged into controller. Three red LEDs 3 Left motor wiring fault Contact your authorized Pride Provider. Three red LEDs 4 Right motor open Make sure right motor is plugged into controller. One yellow LED Three red LEDs 5 Right motor wiring fault Contact your authorized Pride Provider. Two yellow LEDs Three red LEDs 6 Inhibit active Contact your authorized Pride Provider. Three yellow LEDs Three red LEDs 7 Joystick error Contact your authorized Pride Provider. Four yellow LEDs Three red LEDs 8 Controller error Contact your authorized Pride Provider. Four yellow LEDs One green LED Three red LEDs 9 Brake fault Make sure both motors are plugged into controller. Four yellow LEDs Two green LEDs Three red LEDs 10 High battery voltage Contact your authorized Pride Provider.
What if the speed LEDs on the VSI begin to flash? ! Determine if the battery charger is connected to the power base. When the battery charger is connected to the power base, an internal charger inhibit feature keeps the power chair from driving. This is indicated by the VSI speed LED(s) flashing. ! Determine if the charger harness fuse has blown. A blown charger fuse can cause the charger inhibit to activate. ! Determine if all controller connections are plugged into the power base properly. If the 3-pin charger inhibit connector is not plugged in properly, then the charger inhibit feature will activate. What if the speed LEDs on the VSI begin to scroll? ! Determine if the VSI has been placed in lock mode. The VSI is equipped with a lock mode feature that prevents unintended use of the power chair. If the VSI is in lock mode, deflect the joystick full forward until it beeps, and then deflect the joystick full rearward until it beeps. The joystick should go back to the drive function.
Hi, my mother's mobility scooter won't work. The power button flashes constantly. Any ideas how I can fix it?
Many times a brake lever reset can resolve this issue that is preventing the PWC from operating.
MPV5 Power Wheelchair Break LeversMPV5 – The brake levers are located on the front of the Power Wheel Chair just above the footplate. To reset the brakes on the MPV5 Power Wheel Chair make sure both levers are pushed to the down position then pull one lever at a time to the full up position.
FWD and XHD power chair break releaseTEK FWD and TEK XHD - The brake levers are located on the front of the Power Wheel Chair under the label that reads “Drive” and “Push”. To reset the brakes on the TEK FWD or XHD Power Wheel Chair make sure both levers are pushed to the down position then pull one lever at a time to the full up position.
If the lights on the controller continue to flash make sure the controller is not locked.
My shoprider fpc is flashing 6flash 2sec. off 6 again DL5.2i controller can anyone tell me how to find the codes or tell me what this one means.
A 6 blink means the motors are in free wheel position. Turn chair off put freewheel levers in the locked position. You should not be able to push the chair when the motors are engaged. Leave the levers locked then turn the chair on again. If that does not work the motor/s could be unplugged.
2helpful
2answers
My power chair runs but wont move.
re-engage the motors look for two levers one on each motor and move them to locked position
1helpful
Battery fully charged chair levers engaged to drive position chair still will not move.. Jazzy 600.... Tried unlock/lock tried putting it in neutral back in drive with levers still wont move please...
Has your scooter been sitting idle for several weeks, or has it been connected to the charger 24 hours a days for a long time? If so, the batteries may have become damaged and will give you enough power to turn the controller on but not enough to make the motors run.
If the lights come on and are steady, the manual brake levers are in the drive position and the chair still will not move, I recommend replacing the batteries. If anything else were wrong, either the lights would flash or not come on at all.
I hope this information is helpful to you, good luck!
1helpful
Battery fully charged,horn works but no power to drive wheels
Make sure your freewheel brake is in the DRIVE position. Check your owner's manual for the location of the free wheel lever, ususally it is near the rear of the scooter. If the chair is in DRIVE mode but the wheels will not turn, you may have a motor problem which would require replacing the motors.
Wheel chair won't move. Batteries have been charging for several hours and have some charge but chair will not move.Any suggestions? Thanks
Romp, Did you check the freewheel levers chair will not move if you are in freewheel. Levers are in front next to seat posts and need to be facing forward. If you are not in freewheel then check the number of lights you have on on the joystick and that they aren't flashing. Also check that your speed control is not on the lowest setting even with some charge a slow speed setting will not let the chair move. Now by some charge you mean lights in the green on the joystick? If the lights aren't flashing then I'm kinda unsure other than even with some charge the batteries don't have enuf current to drive the motors and need to be replaced Hoe this helps
3helpful
2answers
How to push the jazzy wheel chair when power fails''
There are two levers located on the base of the chair on the left and right sides. Depending on the model, they will be located on top of the base on the front section of the chair base, or on the rear or on the lower sides. Most rotate 90 degrees to disengage the gears so you can manually push the chair. Others are moved up and down, or in and out. Return them to the locked position when done.
Led lights flash and Pride Go chair won't move.
Firstly disengage the drive levers and then "flick "them in fash.
Second pull out the large plug that is between them.
Check for damaged or bent or loose pins. press it home firmly .
I did this on my wifes chair and she zooms around.
All switched etc should be off during charge.
Lastly i fully discharged then recharged the battery to ensure no "battery charge memory".
To fully dicharge i shoved a small box between back wheels so to lift of ground and then a elastic band to hond controler on.
Top Jet Health & Beauty Experts
ADMIN Eric
ADMIN Eric
ADMIN Andrew
ADMIN Andrew
Are you a Jet Health and Beauty Expert? Answer questions, earn points and help others
