The printer is not starting all the time. At some points the printer will take 30 mins to warm up then it will start. Sometimes the printer will just turn on.
SOURCE: My Printer says it is warming up and it wont
i have found that in alot of cases that these units stall on scanner bulb warming because the scanner cannot find home. do you hear a noise like the carriage motor contnues to just move a little bit? what happens is this the ccd knows its home by the brightness of the refected light off of the white carriage home strip on the back side of the glass cover its reflected to a photo cell which is tripped telling the ccd its home. if the bulbs the white strip or the mirrors inside the ccd get a light dusting of dirt on them they dimm this light and the photo cell will not be triped thus creatiing this problem. with a flash light you can see if these mirrrors are fogged. clean them with a q-tip and alcohol. about 65% this fixes it.
SOURCE: THE MITSUBISHI CP8000DW DRIVER IS DISCONTINUED HOW
What OS is your computer running? I found the drivers for supported OS versions here: http://displays.mitsubishielectric.eu/resources/product/CP8000DW . The direct links are listed below. (All are .zip files so you will need to unzip them.)
Mac http://displays.mitsubishielectric.eu/files/library/files/DISCONTINUED/PRINTERS/cp8000m_macos.zip .
Win95-98 http://displays.mitsubishielectric.eu/files/library/files/DISCONTINUED/PRINTERS/cp8000dw_win95-98.zip .
Win NT and Win2K
http://displays.mitsubishielectric.eu/files/library/files/DISCONTINUED/PRINTERS/cpd8000n_wnt4_0.zip .
If you have a newer Windows OS, you can try the compatibility mode. (The NT driver will likely work in XP. If you have Vista or Win7 32-bit OS, it's possible they will work but maybe not. If you have the 64-bit version, the above files will not work directly.) For executable files in Windows, right click on the .exe file and choose properties. Select the Compatibility tab and check Always run this program in the Compatibility Mode. Select the appropriate older version of Windows. Then click Apply. Close the Properties window. Then right click again on the file and choose Run as Administrator (required for Win7 and Vista).
To check if you have the 64-bit OS, click Start > Control Panel > System and Security > System (for Win7). In Vista, the steps may be slightly different. If the version name ends with x64, you have a 64-bit OS. Otherwise, you have the 32-bit version.
If you have a 64-bit OS, you need a 32-bit OS for a work-around. This can be a true second computer, a dual boot system (2 partitions with different OSes loaded), or a virtual computer with an older version of the OS. If you have Windows 7 Pro or Ultimate, you can install a virtual XP computer for free. Go to microsoft.com and download Virtual PC and the XP mode program. Install them in order. Then install your printer under XP as if it were the only computer running. (Note some computer hardware limits may stop you from using this option.) There are other virtual computer programs (VMWare, Parallels). However for the other virtual computer programs or the dual boot or second computer options, you need a licensed copy of the older OS.
I hope this helps.
