Mitsubishi XL8U Multimedia Projector Logo
Posted on Dec 09, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Powers on for only a few seconds
Power light blinks red and green and system does not power up and lamp does not power on
jasbo
Level 3:
  • Master 2,239 Answers
  • Posted on Dec 09, 2009
jasbo
Master
Level 3:
Answers
2239
Questions
Helped
992121
Points
5072
If the power light blinks and the status light is off, check the lamp door. if the power light blinks and the status light is steady red or blinking green, you have a power supply/ballast issue. you may have to send it in for repair. try www.avsolutionsny.com.
Why does my Mitsubishi XD221U projector have a power light blinking red and green?
Reset the lamp timer by holding power and menu button down for 25 secnnds
If you need further help, reach me via phone at https://www.6ya.com/expert/gary_693301a25d57d47d
I'm assuming that it is an error code. The red
colour wheel issues and defective lamp replacing lamp and light engine color wheel cos its worn out
Red light blinks six times. When I hit power button green light stays on for a few seconds, turns off the on for a few more. Then goes back to pattern of red light blinking six times.
the kill switch is open ensure the lamp cover presses firmly on the kill switch when u close the lamp chamber door the red light will stop blinking and u can now turn the tv on
1helpful
Replaced bulb yesterday worked fine. Today light will not turn on. projector turns on both lights green for 10 seconds, then power goes red and status blinks green for about 5 seconds, then status light...
green green is power on, normal
then it tries to light the lamp, but it can't so the protection circuit comes activated.
you get red and green blinking
Then it goes to standby, red and off.
so something has happened to the lamp, or lamp ballast power supply.
Take the lamp out and check if all is OK with the 2 terminals in the connector, and the leads to the lamp are intact.
Failing that, I would suspect the ballast lamp power unit
5helpful
2answers
SONY KDF-E55A20 5 red blinking lights on power button
Symptom shows Lamp is weak in result and causing restart of TV again and again. Your TV requires new lamp as per following part number...
A1085447A* LAMP BLOCK ASSY XL-2200U
It is available in Sony Accessories Store for $200 and replacement procedure is written in instruction manual of TV.
Always buy Sony original lamp for TV and avoid aftermarket / cheap lamp for TV safety.
1helpful
Sony kdf50e 2000- green power light turns red what to do
Does red light blink? if yes, please count blinks as there would be pause of 3 seconds between blinks and let me know to help you out.
1helpful
3answers
Hitachi 55VG825 rear proj television blinking light and screen doesn't light up
Refer to owners manual ! Blinking indicates the type of fault that is occuring on all your tv sets. example : power light on red - indicator light beside it green but blinks rapidly for half a second rapidly then shuts off. This refers to a faulty lamp or a lamp that is near its expiration. Read your manuals if indicators refer to easy repair sweet, but if it says call tech then bummer...
2answers
Toshiba 62HM14
What are the labels on the lights? Timer/Lamp/Service and what color is wich?
Top Mitsubishi Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
Alexander
Are you a Mitsubishi Office Equipment and Supply Expert? Answer questions, earn points and help others
