What do you mean dosnt work is it jammed ?or is it moving too freely causing the bike to bounce? If you try to lift it up from the back wheel dose the wheel move down or lift up with the bike?What do you mean dosnt work is it jammed ?or is it moving too freely causing the bike to bounce? If you try to lift it up from the back wheel dose the wheel move down or lift up with the bike?
You can't post conmments that contain an email address.
If both passengers and drivers side retractable belts have stopped moving, then it's likely the controller that's located under the passengers seat has gone bad. If only one side has stopped retracting and moving then that side motor has probably gone bad.
Just enough pressure that the front and rear of the motorcycle drop together , when you bounce on the seat. If the front drops first when you bounce it might wash out on a corner. If the backdrops first when you bounce on the seat , the rear will tend to skid out on a corner. Set your front and rear shocks to drop together , that is best for extreme riding conditions (you never know when an extreme riding conditions will surprise you.)
the first thing is the fuses. i've seen many of these that the rear air shocks are bad but customer doesnt know and the pump runs until it burns out,after checking the fuses start the car and listen under the hood for the pump to turn on, if pump turns on then check shocks for leaks, also you would have to make sure the pump is producing air as it runs and the last thing is the level sensor located under the rear of car.
Install a new stock spark plug after getting the compression checked and the valve clearances checked. Assuming good compression, use the choke when cold starting but don't flood the engine. Clean the air filter? If, when running, the bike dies when the throttle is turned, remove the jet needle from the throat of the carb and move the clip on the needle down one, possibly two, notches. This will richen the low end mix.
