I thinking that you are talking about "firing order"...
1997 Dodge Caravan FWD 2.4 liter DOHC L4 VIN "B"
and
1997 Dodge Caravan FWD 2.4 liter DOHC L4 VIN "X"
1997 Dodge Caravan FWD 3.0 liter V-6 VIN "3"
1997 Dodge Caravan FWD 3.3 liter V-6 VIN "R"
and
1997 Dodge Caravan FWD 3.3 liter Flex Fuwiring diagram for dodge caravan - 678cb29.gif"G"
Hope this help (remember comment and rated this post).
SOURCE: Dodge Caravan fuse box diagram
buy the service manual.. no other sokution except Chilton's, Motor, etc.
SOURCE: i need a wireing diagram
Will the color code do, or do you need the actual wiring diagram?
1997 Dodge Caravan Car Radio Stereo Audio Wiring Diagram
Car Radio Constant 12v+ Wire: Pink
Car Radio Switched 12v+ Wire: Red/White
Car Radio Ground Wire: Chassis
Car Radio Illumination Wire: Black/Yellow
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Green
Left Front Speaker Negative Wire (-): Brown/Red
Right Front Speaker Positive Wire (+): Violet
Right Front Speaker Negative Wire (-): Blue/Red
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Brown/Yellow
Left Rear Speaker Negative Wire (-): Brown/Light Blue
Right Rear Speaker Positive Wire (+): Blue/Orange
Right Rear Speaker Negative Wire (-): Blue/White
SOURCE: transmission wirind diagram
i have 15 differrent diagrams depending on engine size and your requested circuit, please clarify
SOURCE: Need serpentine belt routing diagram for 1994 Dodge grand caravan
3.3L?
Looking at the engine from front (right side of the Van): Stating at the Top, Going Left to Right and Clockwise:
Over the Alternator
To under the Idle Pulley,
To Over the AC Compressor.
To the Left Side of the Water Pump.
To the Right side and Under the Crankshaft Pulley
To the Right side and Over and Down the Tensioner
To Under the Power Steering Pump
And Back up-to the Left side of the Alternator.
Advise when puting it on:
Put the Belt around everything else accept for the Alternator. After it is around all the rest of the Pulleys - Pull the belt up - tight from the Power steering Pump and the Idle Pulley to form a loop, holding the Belt close to the Altenator Pulley.
Using the 15mm wrench or belt tensioner bar - rotate the Tensioner Pulley towards the front of the Van and then place the belt over the Alternator.
Let me know if this helped or if you have additional information or questions. Feel free to contact me at FixYa.com!
