Verify the number YOURSELF (but likely) BN44-00157a (Very popular: about $36 & up)...
If you (REMOVE ALL POWER) ... take PICTURES...
FORCE NOTHING and
put EVERY wire & fastener EXACTLY back where
you found it you too...
can join the LEGIONS of happy & accomplished
SAMSUNG owners who have repaired their own equipment...
The STATIC WRIST strap is VITAL to you success
(see below)...
? 3:16
https://www.youtube.com/watch?v=kFdVi2ejfzA
May 8, 2014 - Uploaded by ShopJimmy.com
TV Repair Help for a TV With a Black No Image on the Screen ...Sign in to add this video to a playlist. ... LCD & LED TV Repair - No Image & Blank Black Screen Flashlight ... Easiest TV repair - How to Fix Power [TV turns off, freezes, or won't ... 1:26.Samsung LED TV Blank Screen & No Backlights Basic ...
? 1:49
https://www.youtube.com/watch?v=L9cjcsysdW4
Sep 11, 2012 - Uploaded by Roberto Ramos
TV screen begins to flicker then screen turns black while the audio continues to heard. I'm unable to see the TV Menu options when screen turns off. ... After turning the TV OFF then back ON again, the screen will flicker and then ... 1:26. Samsung LEDTV Repair - T-Con Board Replacement - No Picture on ...
Moat likely it is because your power supply is defective and it is not producing tv sufficient voltage to power the backlight. I would replace the power supply.
Sounds like the backlight or backlight inverter is out on your TV.
You will likely want a seasoned professional to repair this for you assuming the TV is out of warranty.
Ur LCD inverter backlight board is dead.Replaced this LCD inverter backklight board.U will get ur picture back.Tries websites Shopjimmy.com,Ebay.com to buy a refurbish LCD inverter backlight board for the replacement.
You more likely to need to backlight inverter boards, thpower supply should have 24vdc for the backlight inverter board, the 24vdc power supply get the trun on command from the controller board, that is what should have been checked first. So look for 24v or measure it directly on the inverter board connector pin. The invereter board also has a couple surface mounted fusesYou can get the inverter board here but make sure to match the number: http://www.shopjimmy.com/catalogsearch/result/index/?q=LN-T4665F+&limit=100
Your LCD TV uses backlights and they can be slightly visible when viewing a letterbox movie. However, if the light is really bleeding into the black, there could be a problem, but mosty this is common.
before you give up..call samsung directly, they are very consumer oriented and if it is only a couple months out of warranty you might get them to repair it,, 1 800 samsung
