After trying to turn the channel yesterday on my Samsung LCD HDTV (32"), a black box in the top...
(More)
After trying to turn the channel yesterday on my Samsung LCD HDTV (32"), a black box in the top middle said "MUTE." After that, the sound has not worked. I've tried to adjust the volume, but nothing is working? What do I do?
Using digital cable. Screen went black, but can still hear sound. Checked all connections, reset...
(More)
Using digital cable. Screen went black, but can still hear sound. Checked all connections, reset cable - still no picture. Cannot see to access onscreen menu. There is a tiny white block visible in the top left corner of the screen. Help please - is this a TV problem or a cable problem? Thank you.
I have a samsung LNT4665fx. It turns on just fine, and the screen looks normal. After about 15...
(More)
I have a samsung LNT4665fx. It turns on just fine, and the screen looks normal. After about 15 seconds, it goes "black". If you look closely, you can see that the picture is in fact there, and functioning normally, just no light. The first 2 times this happened, I unplugged the TV for several minutes, plugged it in and it went away. This time it is not going away.
hdmi sound dropping out intermittently. Can be corrected only by power-off or going thru menus and...
(More)
hdmi sound dropping out intermittently. Can be corrected only by power-off or going thru menus and reselecting hdmi This has been a long term problem.
Same thing is happening to me after playing with my xbox. It turns it self off after a few seconds...
(More)
Same thing is happening to me after playing with my xbox. It turns it self off after a few seconds and just keeps flickering the power on and off and fails to turn on most of the time. HELP!
The problem:Press the power button and the led turns blue, but nothing happens. I figured out that if i unplug the set then plug it back in it worked....
written by stiv0
Vizio Tv's have an extra menu that contains factory settings which you can change or fix should you have a problem with your TV.
Here's how to...
written by TechNerd
If an LCD TV has sound but no picture do the following: Use the source button to ensure that source is not set to the wrong input.
Try unplugging...
written by ginko
The first thing to check is the cables connected at the back of the TV.
Check cable connection, and try using a different cable, video signal
is...
written by ginko
You can help other;s and maybe they will help you. This can be done by
uploading a copy of you user manual and any service information for...
written by stoneheaded
The codes are at this website:( http://tech.dishnetwork.com/departmental_content/techportal/content/tech/remotes/TechRemo5.3Code.shtml ) Just put the...
All Polaroid flat panel I have a FLM-3203 32 inch LCD. After reading so many posts on replacing the to 10v caps I decided to do this to mine. After...
written by prowler21
When you have a damaged or unrepairable television it may seem like a total loss and ready for the trash. Instead of trashing the television, why not...
Most people just put their plasma TV on a stand on a table or other furniture. But what fun is that? One of the cool things about having a TV that's...
by wikihow
If you have an old TV but want to watch DVDs, you may have difficulty hooking up your DVD player. Most DVD players have a yellow RCA video output...
by wikihow
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQU... Read More
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC EQUIPMENT, TECHNICAL CONSULTATION, REPLACEMENT OF LAMPS IN LCD AND DLP PROJECTION TELEVISIONS.
QUALITY SERVICE AND REASONABLE PRICES.
