RIM BlackBerry Curve 8520 Smartphone Logo
Posted on Apr 09, 2010
Blackberry 8250 trackpad frozen
I can't scroll anywhere, it unfreezes occasionally then it will freeze up again. When it freezes the only functionality I have is what ever it froze on top of. ie. if I was sending a text to Mike, the only ting I can do is text Mike. And sometimes I can only receive and not send. I can call out using numbers, but I can't get to my recent calls or phone book. I Have removed the battery several times, this does not work
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Apr 28, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
2890
Points
On the application Blackberry App world download QuickPull free, then set it to reboot often to free up your MB. This should reduce the number of times it freezes :)
Anonymous
Level 1:
New Friend:
  • Contributor 2 Answers
  • Posted on Feb 24, 2013
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
2902
Points
I understand what your saying because i have a blackberry and it will be fine one minuet but then i try to scroll and it is frozen but however i have a soloution if you go on blackberry app world and download quickpull for free problem solved hope it works
How to factory reset
Follow below steps:
From the home screen, scroll to the All tray and press the trackpad.
Scroll to Options and press the trackpad.
Scroll to Security and press the trackpad.
Scroll to Security Wipe and press the trackpad.
Scroll to the desired options and press the trackpad to check or uncheck as desired.
Enter blackberry in the text field.
Scroll to Wipe Data and press the trackpad.
The handset will completely reset and restart.
This will take several minutes.
Cell freeze 3 rows together at a time.
Freeze a Row in Microsoft Excel
Microsoft Excel 2010 can freeze, or lock, a top row as you scroll down the worksheet.
For example, you may need to keep the top row of column titles visible at all times.
The "View" tab on the command ribbon contains the "Freeze Panes" button in the "Window" group.
A single row or a range of rows can lock through the "Freeze Top Row" or "Freeze Panes" options.
Open the Excel worksheet.
Click the top row heading.
The row heading displays a number just left of the first column of cells. The selected row appears shaded.
Click the "View" tab on the command ribbon.
Click the "Freeze Panes" button in the "Window" group.
A list of options appears.
Click the "Freeze Top Row" option.
A black horizontal line appears on the worksheet.
This line indicates the locked row that stays on the screen as you scroll down the worksheet.
http://office.microsoft.com/en-us/excel-help/freeze-or-lock-rows-and-columns-HP010342542.aspx?CTT=1
Freeze or lock rows and columns
also
Use Freeze Panes in Excel
Scrolling down to look at a number and then scrolling up to make sure the number you looked at is under the header you expected is not an efficient way to view a spreadsheet.
The Freeze Panes feature of Excel allows you to freeze the labels of your data in place while you review the data.
Follow the instructions in Section 1 to freeze the top row or the left column.
Freeze multiple rows, multiple columns, or rows and columns, by following the instructions in Section 2.Freeze the Top Row or Left Column
Open the Excel spreadsheet.
Navigate to the "View" tab on the top menu.
3 Click on "View," then click on "Freeze Panes." A drop-down menu opens.
Select the "Freeze Top Row" option to freeze the top row.
5
Select the "Freeze Left Column" or "Freeze First Column" option to freeze the left column.
6
Freeze the top row by using the keyboard and sequentially pressing the keys "ALT, W, F, R." Ignore Steps 3 through 7 if using this choice.
7
Freeze the left column using the keyboard by sequentially pressing the keys "ALT, W, F, C." Ignore Steps 3 through 7 if using this choice.
8
Unfreeze panes by repeating Steps 3 through 5 and selecting "Unfreeze Panes" or sequentially press the keys "ALT, W, F, F."
Freeze Rows and Columns, Multiple Rows, Multiple Columns, or Multiple Rows and Columns
9
10
Freeze column(s) and row(s) at the same time by selecting the cell to the right of and below the location you want to freeze.
11
Freeze multiple rows only by selecting the cell in the left (first) column below the rows you want to freeze.
12
Freeze multiple columns only by selecting the cell in the top row to the right of the columns you want to freeze.
13
14
15
Select the "Freeze Panes" option. You have now frozen the columns or rows, or columns and rows you designated.
16
Freeze panes using the keyboard by sequentially pressing the keys, "ALT, W, F, F." Ignore Steps 5 through 8 if using this choice.
17
Unfreeze panes by repeating Steps 5 through 7 and selecting "Unfreeze Panes" or sequentially press the keys, "ALT, W, F, F."
http://office.microsoft.com/en-us/excel-help/freeze-or-lock-rows-and-columns-HP001217048.aspx
http://office.microsoft.com/en-us/excel-help/demo-hide-or-unhide-rows-and-columns-HA010241040.aspx
Hide or show rows and columns
Trackpad keeps freezing
Do you have an added Apps? One could be causing the problem.
The other reason could be the pad is getting wet or moisture on it. Also it is not required to press ******* the pad, maybe too much pressure. Also check sensitivity settings
Out of curiosity, have you tried a battery pull yet? While the phone is on, simply remove the battery, for good measure, wait a full minute, then reinsert the battery and wait for the device to reboot.
Does that help? If not, let us know what operating system you're running on your phone. You can get this info under Options > Device > About Device Versions, or by typing "myver" in a text box (e.g. email or BBM).
My phone is like frozen
If your Phone Freezed or frozen means it's samsung mobile?am i rite...If so means You need to Unfreeze it,you can use the Unfreeze Code to Unfreeze the Phone,You can get the Unfreeze Code from here
Wickedunlock and Unfreeze it...
My blackberry scroll pad is not working, and i can't scroll anywhere. i took it to the shop and the man told me it was a hardware problem, i have pop reset it and soft reset it and nothing seems to work. i...
hi Titchypink.
this is all i could find out,hope it helps you out.
Trackpad, trackball, or keyboard not working on a BlackBerry smartphone running BlackBerry OS 7.1 and earlier Article Number: 000029640 First Published: April 26, 2017 Last Modified: April 26, 2017 Type: Support
Environment
  • BlackBerry smartphones running BlackBerry OS version 6 to 7.1
  • BlackBerry smartphones running BlackBerry Device Software 5.0
Back to top ?
Overview
In some situations, a BlackBerry smartphone with a trackpad or trackball may experience issues with sensitivity, latency, or scrolling. Additionally, the BlackBerry smartphone keyboard, or other buttons may be unresponsive.
Back to top ?
Cause
This issue might be caused by one of the following:
  1. The trackball/trackpad sensitivity needs to be adjusted.
  2. Make sure the trackball/trackpad is not affected by a software freeze or an application freezing.
  3. The BlackBerry Device Software is out of date and requires an update to resolve the trackpad, trackball or keyboard issue.
  4. The physical trackpad, trackball or keyboard hardware is malfunctioning.
Back to top ?
Resolution
Resolution for Cause 1
Complete the steps in Article 5447 to ensure the trackball/trackpad sensitivity is correctly.
Resolution for Cause 2
For BlackBerry smartphones running BlackBerry OS version 6 to 7.1 using a trackpad, complete the following:
  1. From the Home screen, select Options.
  2. Select Typing and Language.
  3. Select Trackpad Sensitivity.
  4. Ensure Audible Roll is selected.
  5. Rapidly roll the trackpad up, down, right, and left.
  6. If an audible click is heard while not responding, proceed to Resolution for Cause 4 as this could be a software related problem.
For BlackBerry smartphones running BlackBerry Device Software 5.0 using a trackball, complete the following:
  2. Select Screen/Keyboard.
  3. Ensure Trackball Audible Roll is selected.
  4. Rapidly roll the trackball up, down, right, and left.
  5. If an audible click is heard while not responding, proceed to Resolution 4 as this could be a software related problem.
  6. If an audible click is not heard, the problem may be related to a hardware issue. Please contact the wireless service provider for additional steps.
Resolution for Cause 3
To update BlackBerry Device Software using BlackBerry Desktop Software see, Article 11320.
or
To update the BlackBerry Device Software on the BlackBerry smartphone visit http://www.blackberry.com/update/
Use the BlackBerry Virtual Expert diagnostics application. For more information, see Article 35973.if not try this link. blackberry scroll pad is not working Google Search
1helpful
2answers
My Blackberry Bold 9700's Trackpad keeps freezing. I can click to open items but can not scroll anywhere.
i have the same problem. i could click to open items using my trackpad but it doesnt move, cant scroll thru my phone :s
3helpful
2answers
Trackpad freezes BB 8520 Options
i know what ur talking about and its so annoying what i do is i take the battery and sim card out and then put them back in and it seems to work only tho it takes forever!!!!
2helpful
2answers
Well my ds lite freezes,is there a way to unfreeze it without turning it off
As far as i'm aware there is no way to unfreeze the DS lite once it has frozen apart from turning it off and on again.
Sorry.
Regards,
SOD69
Side by side freezer freezes then unfreezes
With the thermostat turned to its coldest setting can you hear or feel the compressor running? Can you find the defrost timer inside the refrigerator and turn it until the compressor stops, and then please let me know, the defrost time may be bad and sticking or slow leaving the refrigerator in defrost too long, let me know soon
Blackberry pearl 8130 issues
take the battery out of the phone then place it back in the phone and try again, if it freezes again then you have a software problem and you will need to take the phone into a repair center and have it diagnosed.
Top RIM Cell Phones Experts
Grand Canyon Tech
Grand Canyon Tech
Kolbrun...
k24674
Are you a RIM Cell Phone Expert? Answer questions, earn points and help others
