Lexicon Omega Desktop Recording Studio Sound Card Logo
Posted on Apr 09, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How I can to installer a sofwer compatible to windows vista? for lexicon omega studio
Anonymous
Level 2:
  • Expert 63 Answers
  • Posted on Apr 09, 2010
Anonymous
Expert
Level 2:
Answers
63
Questions
0
Helped
24683
Points
105
At first resistering your product. then you download your vista driver on lexicon website; thanks
Hello i opened my lexicon omega and the cd wont download, i have tried a number of things but it keeps coming up with stienberg softwear, i have registered but the lexicon omega will still not load onto...
The software is by Stienberg and is called "Cubase" that is delivered with the Lexicon. The Omega doesn't really have any software to speak of except for the drivers. Browse the software disk looking for the section containing the drivers. When you install it, it will create a Lexicon folder with the root of your C drive and in it will be an Omega folder. In that is a driver folder and a folder of help files. In the Driver folder folder you will find the installer file "Omega Setup". Launch that program to install the drivers. Please note I have one of these and it can be frustrating to get things working. Make sure in the PC in the control panel "sounds and devices" that under the tabs that the Omega is the device to send and receive and for voice. Once you have done the install, the Omega should be in the list of available devices to select as default.
I have a lexicon omaga drive but when i hook it up its like i need a 64 bit driver
Don't know what OS you're running. Omega has published drivers for Vista and 7 64-bit versions. They say they don't support XP 64, but when I hooked my unit up to my computer and the hardware install wizard came up the OS found and installed Microsoft published general USB audio device drivers for all inputs, midi, and mac USB channels of the Omega, and automatically set it as my default device. I hooked headphones into the Omega unit and could hear system sounds. So far so good. Went to My Music and fired up an audio file. Windows Media Player started up and the song started playing but I couldn't hear anything. Opened the same file with Audacity, could see the VU meters bouncing, but still no sound in my headphones. Went in to the preferences of Audacity, and manually set the speaker default to the Omega mac USB device. Hit play again and voila! I had sound. Closed the file, started WMP manually, went in to options, and again set the speaker default to Omega mac USB. Opened the same audio file and this time it played just fine. The driver files Windows used for my card were
C:\\WINDOWS\SysWOW64\ksproxy.ax, C:\\WINDOWS\System32\drivers\ks.sys, C:\\WINDOWS\System32\drivers\ksthunk.sys,
C:\\WINDOWS\System32\drivers\portcls.sys,
C:\\WINDOWS\System32\drivers\stream.sys,
C:\\WINDOWS\System32\drivers\USBAUDIO.sys,
C:\\WINDOWS\System32\ksproxy.ax,
C:\\WINDOWS\System32\ksuser.dll,
C:\\WINDOWS\System32\wdmaud.drv,
all version 5.2.3790.1830
Hope this helps everybody else with this problem.
2answers
I would like some help to setup my new omega desktop recorder on a pc lapp top running vista vista home preminum
What sort of help do you need?
http://www.lexiconpro.com/product.php?id=6#downloads
There are some helpful files here for the omega lexicon pro.
Hope this helps!!
WDM Driver failed to install is the first of four
Make sure you verify that your computer meets the requirements for the Omega. I have one of these and it installed on an XP with no problem.
Maybe you have Vista instead of XP. OFTEN there are incompatibilities of Vista. If you have that or heaven forbod Windows 7, you may either need a different WDM or have to backstep to the XP operating system.
In short, VERIFY the requirements of teh Omega and its software with the OS and system you are trying to install it on.
A last thing to try is to install it while in "SAFE MODE".
Omega Lexicon sound card refuse to set up
If you are trying to set it up on a new computer it probably has Winsows Vista. The older cd is probably setup for Windows XP and below. You should be able to download the Vista installation package & drivers from the manufacturers website. Just click the Support link and lookup your specific model #; select Vista as the operating system and the files should appear. Download and Install and you should be all set. Hope this helps.
Omega Studio won't record to computer
The omega is like an external sound card. It has to be connected via your computer with a device driver,the software that came with the lexicon. Then you record on a software program such as Cubase.
Go to the guitar center for more help or go to google .com and type in lexicon omega. Lots of sights to look for answers or better yet go to lexicon omega's home site.
2answers
Lexicon Omega USB on new HP Dual core laptop pc running vista 4GB Ram
You said the magic phrase premiume HOME computer...
and the key word VISTA.
I've heard of VISTA pro running this but the home version is really not that robust for the type of gear you have there.
vista just has to many bugs.
go back to xp pro sp2 for good results.
good luck
44hink
2answers
Cubase and Lexicon Omega
Yep that's Vista for you! Try microsoft. com for a patch or the product's website.
Installing omega lexicon desktop recording studio
Yes it's extremly tempramental, just keep repeating the proces it' will work eventually!
Top Lexicon Computers & Internet Experts
Larry Ng
Larry Ng
ADMIN Eric
ADMIN Eric
Don A
Don A
Are you a Lexicon Computer and Internet Expert? Answer questions, earn points and help others
