Question about Lexicon Omega Desktop Recording Studio
Hello i opened my lexicon omega and the cd wont download, i have tried a number of things but it keeps coming up with stienberg softwear, i have registered but the lexicon omega will still not load onto my computer. if someone could help me it would be alot of help. thanks alot
Posted by jamespelley8 on
Fred Yearian
  • Lexicon Master
  • 5,603 Answers
The software is by Stienberg and is called "Cubase" that is delivered with the Lexicon. The Omega doesn't really have any software to speak of except for the drivers. Browse the software disk looking for the section containing the drivers. When you install it, it will create a Lexicon folder with the root of your C drive and in it will be an Omega folder. In that is a driver folder and a folder of help files. In the Driver folder folder you will find the installer file "Omega Setup". Launch that program to install the drivers. Please note I have one of these and it can be frustrating to get things working. Make sure in the PC in the control panel "sounds and devices" that under the tabs that the Omega is the device to send and receive and for voice. Once you have done the install, the Omega should be in the list of available devices to select as default.
Posted on Apr 16, 2011
Lexicon MX200 screen coming up as "ER", nothing else happens, and no sound
hello I have the same problem, I'm told that updating the firmware of the Lexicon MX200 is solved but it turns out that my pc does not recognize the device via USB to update, any solution? thank you very much
Jul 06, 2011 | Lexicon Mx200 Reverb Delay 1u Effects...
I have an Omega/Lambda/Lexicon and the vocals seemed to be delayed with the timing established by the instruments. Any ideas of what to do?
Without the configuration you are using we have little to go on. How is the system wired? Are you saying when you run instruments AND mics into this then record they do not play back together? If the instruments are MIDI types and you play back along with the vocals I would expect the MIDI instruments to be delayed a little as it takes time to transmit the note info at 31.25Kb... It takes about 1/3000 second for EACH MIDI character and note messages take three of those for a total of about 1 ms. One millisecond IS noticeable by the ear... and if you have several instruments it may take several milliseconds to service all the instruments. If you are recording ANALOG instruments the delay should be imperceptible.
Apr 26, 2011 | Lexicon Lambda 4x2x2 USB Audio Interface
Hi, I bought a Lexicon Alpha in order to use with Apple Mac (Logic). Now, my microphone is a dynamic microphone so it does not need any phantom power. When I connect the usb cable, the blue light comes...
I suspect the problem is with the software setup in your PC. Verify all the options and also verify that the AUDIO system is assigned as stereo and assigned to the Lexicon for both in and out... Also check any "PAN" control settings. There is a possibilty that the Alpha has a dead channel...
Try putting a stereo signal into the 1/4 inch jacks and see if both record... if NOT then take it for repair under warranty... I had a Lexicon Omega that had a problem myself... warranty repair...
Jan 10, 2011 | Lexicon Alpha Personal Recording Studio
Lexicon omega usb board burn in two places part[80-0112-b]digital B D
One can burn up equipment if you have powered parts of it from different sources...such as connecting things together that get their power from different receptacles. Ground bounce and fault currents of defective equipment can burn up things. You will probably have to send your unit back to the factory for repair.
Jan 08, 2011 | Lexicon Omega Desktop Recording Studio
Im having a problem with hearing my b-1 studio condenser mic on the lexicon alpha progam?
Sorry but... Very simply, you CANNOT use a condenser mic with the Alpha since it does not supply the required Phantom power for the mic. You must step up to another interface to use condenser mics. You can use dynamic mics with the Alpha or other audio sources. I use a Roland/Cakewalk UA25E interface with condenser mics and also the Lexicon Omega which does have Phantom power for the mics..
Nov 03, 2010 | Lexicon Alpha Personal Recording Studio
Have just purchased lexicon alpha to use on a Mac. Having trouble just getting started. Have hooked up a nice condenser mic into the alpha through the mic input on the rear and cannot get anything on the...
Make sure you have Phantom power turned on on the Lexicon... Oh,oh... it appears that the Alphs may NOT have phantom power which IS a REQUIREMENT for most condenser mics...
The Lexicon Omega does have this but apparently the Aplpha doesn't have it.
That leaves you with the choice of either getting a dynamic mic that doesn't need Phantom, or replacing the Alpha, OR using a preamp ahead of the mic before the Alpha...
Sorry, but those are the only solutions I see for you.
REMEMBER that condenser mics pick up everything and you cannot run them into a PA or they will feedback.
Oct 08, 2010 | Lexicon Alpha Personal Recording Studio
WDM Driver failed to install is the first of four
Make sure you verify that your computer meets the requirements for the Omega. I have one of these and it installed on an XP with no problem.
Maybe you have Vista instead of XP. OFTEN there are incompatibilities of Vista. If you have that or heaven forbod Windows 7, you may either need a different WDM or have to backstep to the XP operating system.
In short, VERIFY the requirements of teh Omega and its software with the OS and system you are trying to install it on.
A last thing to try is to install it while in "SAFE MODE".
Nov 13, 2009 | Lexicon Omega Desktop Recording Studio
Lexicon Omega Desktop Recording Studio Logo
206 people viewed this question
Top Lexicon Music Experts
Marvin
Marvin
Are you a Lexicon Music Expert? Answer questions, earn points and help others
