Here are some possible problems and solutions:
- Insufficient water suppy. Make sure your using a 3/4" diameter hose, The more length of hose the less water pressure you have so keep the supply hose as short as possible.
- Plugged Pump Inlet Filter. Check and Clean.
- Wrong Nozzle. Make sure you have a high pressure nozzle installed on the wand.
- Plugged Nozzle, inspect and clean.
- Worn Nozzle, inspect and replace.
- Leak in pressure hose, inspect for damages and replace if any.
I Hope This has helped, please rate the answer if it has been helpful. Good Luck and have a great weekend.
