I have an ibm thinkcenter with windows xp professional sp3 and when i boot it up it boots normal until it gets to the point after it loads xp just before the desktop comes on the screen usually says windos xp system starting but now im getting just the windows xp logo and nothing will happen after that. the my computer icon and a few others were missing before i rebooted the computer to try to bring them back. i was messing around and accidentally deleted some registry keys. i do not have a boot disk or any repair disk to reformat my harddrive. what can i do to get my computer back to normal?
Log in using SAFE MODE. While laptop boots, press F8 and it will prompt for which mode to login. Select 'SAFE MODE'. Once logged in try to restore the OS to a previous good restore point.
If you've a backup of the registry key, it will help better. Just restore the registry from the backup instead of going for an old restore point.
Please come back and rate my solution if this turns to be helpful for you or also if you need more clarification.
Thnx
Testimonial: "good idea but i just tryed i and it still gets stuck at the same screen in safe mode"
Then i would suggest you to get a bootable disk from internet and use your key to install the OS again. Do not format the any drive, let it be just an 'inplace' re-installlation. This could save the applications installed already. If even it wont work, then better you format and install.
Appreciate your response on my solution.
