The thermostat in the northstar engine is located at the bottom radiator hose (unlike most conventional cooling systems), the hose connects into the housing where you will also find the water pump.
Remove the hose from the housing,then remove the two bolts on the flange,the thermostat can then be pulled out.
Take note of the orientation of the thermostat as you remove it.
Don't forget the new gasket, you may have to order this separately.
DeVille, Eldorado, Seville 1999-2005
Thermostat - Removal & Installation
Fig. Thermostat and housing-typical
To install:
Hope this help (remember rated and comment this) TY for using Fixya.
SOURCE: replacing the thermostat on a cadillac deville
drain half of the coolant.follow top hose to the thermmostat housing .loosen hose clamp then loosen the thermostat bolts.remove the thermostat housing and thermostat.remove traces of all the old gasket from housing and the intake where thermostat goes.becareful dont scratch the surfaces while removing all the old gasket.this info is for the 4.9 models.now for the 4.6 engines. you have to remove radiator support cover .remove the air filter housing.loosen hose clamps .remove your thermostat housing bolts then thermostat.remove traces of all old gasket.on thermostat housing and intake. then put in new thermostat in. put on housing .torque bolts 18 to 20 ft lbs.
SOURCE: 2001 cadillac deville, overheats without loss of coolant
First, provided their are no visible coolant leaks and/or loss of coolant with no signs of leaks, I would thoroughly flush cooling system and replace coolant, then check and/or replace thermostat (you can place thermostat in boiling water to check for proper function), if you have tried these 2 steps and still are experiencing overheating you may need to replace your water pump which can be a tricky job if you're unfamiliar and try to do it yourself, however, I could walk you through it if necessary. Also visually check your radiator hoses for bulges, wear ,etc along with heater hoses etc. You may want to also check radiator fins to see if they are dirty/obstructed and clean if necessary. Let me know if I can assist you further and how it works out
SOURCE: Replacing the thermostat on a cadillac deville
Assuming you have the Northstar engine....
Don't forget the new gasket when you install your new stat.
SOURCE: HOW DO YOU CAHNGE THE THERMOSTAT ON 2002 CADILLAC DEVILLE
The most common overheating problem with the Northstar engine is a blocked purge line. It's job is to purge air out of the cooling system.
There is a small diameter hose coming from near the top of the coolant tank,this is the purge line.
With the engine idling,pull the purge line from the tank,if there is no coolant flow from this small hose,it is blocked and this will cause overheating.If the hose is clear, check for blockage at the nipple on the tank.Or trace the hose back until you find the blockage.The hose goes in to the engine to a crossover and comes out the other side to near the thermostat housing,the blockage may be there.
SOURCE: need to locate where my 2001 cadillac deville
You will need to remove the air filter housing and air duct to gain easy access to the thermostat.
The thermostat in the Northstar engine is a duel action device.
One end of the stem is the Thermostat(obviously) and at the other end is a spring loaded pressure valve(the thinner end).
Make sure the thermostat end is nearest the rubber hose and the pressure valve end is in towards the engine.
Don't forget the new gasket when you install your new stat, you may have to order this separately.
Overheating........
The most common overheating problem with the Northstar engine is a blocked purge line(small hose).The purge line is designed to purge air out of the cooling system.
There is a small diameter hose coming from near the top of the coolant tank (not the cap) ,this is the purge line.
The hose goes in to the engine to a crossover and comes out the other side close to the thermostat housing,the blockage may be there.
Also note that the cooling fans don't come on until the coolant temperature hits around 225 degrees.
During normal highway driving the fans will very rarely come on(if at all) due to constant air flow through the radiator.They will only usually come on in heavy traffic conditions on a hot day.
But......if you have the Air Con switched on, the fans will run all of the time.
