At start up the monitor either goes to black or goes very very dim only readable via sunlight.
Checked all display settings (brightness...etc) and I pushed them to 100% and still nothing.
I am running Vista and this is a 19" widescreen monitor.
I assume that you already try this monior with other PC and still get the same problem. You may have to open it up and inspect the inside, look for bad components such as capacitors in the power supply, the problem can also be inthe backlight inverter circuits also. See example of failed monitors: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further.
