Acer AL2016W 20" LCD Monitor Logo
Posted on Oct 13, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
'Shadows' behind all texts and images on the screen
I'm seeing everything double, and it's not because of my eyes! How can I remove the greyish 'shadows' behind all the images on the screen?
  • Anonymous May 11, 2010
    Is the monitor connected by a digital (dvi) or analog cable?
Anonymous
Level 1:
New Friend:
  • Contributor 12 Answers
  • Posted on Feb 07, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
12
Questions
0
Helped
23214
Points
61
[u][b]LCD Monitor Shadow Effect[/b][/u]
This problem is best described as the LCD monitor "Shadow Effect".
The solution to this very simple. No software or hard ware changes required.
The cables that are connected to the LCD monitors are causing the problem. Its also called as electromagnetic noise or electrical noise.
[u][b]Solution: [/b][/u]Keep the two cables - (power cable and moitor display cable), that are connected to the LCD monitor as far away as possible with each other and also away from other electrical cables.
Thats it. Your shadow effect is fixed.
Thank you.
  • 3 more comments
  • Anonymous Apr 14, 2013
    Brilliant! Cables were in a mess behind the monitor!!! After turning ever thing off and a tidy up the scree came right. Thank you.
  • Kelvin Sanchez
    Kelvin Sanchez Jun 10, 2014
    Kelvin: Excellent. A genius couldn't advise me better. I untangled all my cables and, Voila!! Problem went away. Thank You.
  • Donnie W
    Donnie W Apr 29, 2021
    Same! Separated my cables and problem solved! Genius!
  • Anonymous May 01, 2021
    and told in the manual for it to do that.
    amazing no?, RTM.
    RTM = Genius.
  • P&P GAMING
    P&P GAMING Nov 12, 2022
    Sir, your solution fixed my problem uoto a limit but still there is some shadow effect left on my monitor screen.. Can yiu plz tell me that do the quality of the VGA cable matters or its an internal problem?
Denise
Level 2:
New Friend:
Cheetah:
An expert who has answered 20 or more questions within one hour.
  • Expert 151 Answers
  • Posted on Apr 29, 2014
Denise
Expert
Level 2:
New Friend:
Cheetah:
Answers
151
Questions
Helped
56604
Points
199
The "shadowing" you talk about is due to cables in back of your computer, touching or too close together. I had this happen to mine. I separated, moved the cables apart, and no more shadows !! Sounds too easy, but it works. Try it.
Mohamed Alazhary
Level 2:
New Friend:
  • Expert 96 Answers
  • Posted on Apr 29, 2021
Mohamed Alazhary
Expert
Level 2:
New Friend:
Answers
96
Questions
0
Helped
39423
Points
130
Replace the display cable.
1helpful
Screen blue shadows laptop
See if you can set the sharpness a little lower in the monitor setup on the pc, not the monitor first. Then try sharpness on the monitor.
How do I get rid of shadows on my printing from my HP Photosmart C3180 printer? There is an extra shadow behind EVERY single piece of text. It makes the whole page look blurry. It isn't as if t
I have a Canon printer. Whenever pictures or text gets a double or blurry image I open the printer solutions menu. It sounds as though there is a problem with inkjet alignment. By clicking the realignment button the printer will automatically realign the jets. I usually test the alignment by printing a page from that program. All the line segments should line up.
Rarely used Tasco 3087GY Binoculars. The problem is that it feels like you are looking cross eyed when using. Each eye can be focused perfectly independently but when looking with both eyes, it's like...
EARTHS TRANSFORMATION INTO THE 5TH DIMENSION I WOULD LIKE TO SHARE WITH ALL THE OCCUPANTS OF MOTHER EARTH THE
REASONING BEHIND THE "DOUBLE SHADOW". MOTHER EARTH HAS BEGUN A
SERIES OF EVOLUTIONARY TRANSFORMATIONS, ONE OF WHICH IS
AFFECTING THE NORTH POLE, OR MAGNETIC POLE, THE REASON FOR THE
NOW "QUADRUPLE SHADOWS" IS THE EARTHS ROTATION SPEED. EARTH IS
PREPARING FOR A DIMENSIONAL SHIFT, FROM A 3D TO 5D. HENCE THE
REASON FOR BINOCULARS TO SHOW DOUBLE IMAGES, THEY AREN'T BROKEN,
THE "FUZZ" OR "FREQUENCY SNOW" ALL AROUND, VISIBLE TO CAMERAS,
RECORDERS ETC. THE SHADOW ENHANCEMENT AND VISUAL INTAKE OF SUCH,
ALSO SEEMS THAT BLURRY IS EVERYWHERE, IT IS NOT YOUR VISION, IT
IS THE MAGNETIC ENERGY , NOTHING SEEMS TO WANT TO FOCUS, SEEMS
AS THOUGH THERE IS A MIST OR FUZZY FILM EVERYWHERE. tHESE ARE
THE PHYSICAL SIGNS OF THE EARTHS NATURAL AND NECESSARY CHANGE.
NOW IS THE TIME FOR ALL TO FILL THE EARTH WITH LOVE, LIGHT
HAPPINESS AND INNER PEACE. I PUSH INTO ALL OF YOU , HAPPINESS,
JOY AND LOVE. lIGHT SHALL BEAM THROUGH AND AROUND ALL OF YOU
AND YOURS. POSITIVITY AND AWAKENING TO ALL WITH LOVE.
5helpful
3answers
The monitor is showing doubles or shadows of every image on it. from icons on desktop to text in web browser and every other detail.
If it has a removeable cable between the PC and screen, try removing it and plugging it in and trading ends (plug the end that was in the PC into the back of the screen and vice-versa...) If the connector is even slightly loose or the cable is going bad it will cause the problem you're having, and as long as it's removeable you can easily get & replace the cable... Good luck!
5helpful
Multi-color double images or shadows and curved screen
Alrighty, very common problem on this set. Here's a rundown of the repair if you're a DYI:
With the back cover off you'll notice a set of boards on the bottom of the TV and a pair of boards sitting up over the two bottom boards. The problem lies in the upper-right hand board which is the color convergence power supply. Either replace or repair this board. The repair involves the main power mosfet (a three legged regulator on a heat sink) and two diodes next to it.
Next, the bottom right hand board needs to be removed and a fuse replaced next to the flyback. If you are versed in electronics I can detail the repair further otherwise you're going to have to have a shop do the repair.
Shadows and text curved. Double images
The convergence IC's need to be replaced. The generic part # on them is STK392-110. This is not easily done by yourself.
Double image on green
Focus won't help if it is a double image. Sounds like convergence amps need to be replaced. Very typical on these.
Double Images / Shadows on the monitor screen
Hi..there,
Have you guys...try to open your OSD on your monitor and blanced the colors or adjust the WB (white blanced) settings....
35helpful
10answers
I read through other solutions to this problem because I had the same problem. I checked to make sure electrical cords were properly attached, and vola! problem solved! I had no idea this problem could be fixed just by checking the cord connections. Thanks a million for posting this solution. I had been putting up with the shadowing, streaking for months! You really made my day.
Hit 53UWX10BA
convergance ic bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
Steve Sweetleaf
Steve Sweetleaf
Grand Canyon Tech
Grand Canyon Tech
