Jenn-Air JGR8775QDS Gas Kitchen Range Logo
Posted on Mar 09, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Clear code My Jenn Air has a code of 5Ab bATH it came on when I tryed to reset clock. Held button in and this came up. Have unplugged to try to reboot but it did not help.
  • Anonymous Apr 06, 2009
    This has been the worst range I have ever owned. I will never buy a Jenn Air again. When it was new, (now about 3 years old) it had a gas leak for almost 6 months. Repair men couldn't fix, finally someone did. Now the door won't unlock after cleaning, and the Sab light is on. Any suggestions for this lemon?
Anonymous
Level 3:
  • Master 5,911 Answers
  • Posted on Mar 09, 2008
Anonymous
Master
Level 3:
Answers
5911
Questions
6
Helped
2735859
Points
22413
This is a frequently reported problem on some model ranges and wall ovens equipped with an Electronic Range Control (ERC) or Electronic Oven Control (EOC). An “error” code display of “Sabb" or “Sab” will be displayed and the range or oven will not function. This is called “Sabbath Mode" and it may be costing you unnecessary charges in service call fees. This is NOT a problem, but actually a feature provided by some manufacturers to enable customers of certain religious faiths to honor the Sabbath. The range will not function at all during this period and cannot be reset by unplugging the unit or turning it off. In your owner/operator's manual there should be a section that refers to "Sabbath Mode" under the control panel features and operation. This "problem" is a minor operator issue and is not a malfunction of the appliance. This is commonly reported by customers to service companies to have corrected, but the repair is unnecessary, and usually NOT covered under the manufacturer’s warranty. The reason: It is a designed feature of the appliance and considered “operator error” in most cases. What this means is you may be paying someone big money to push a couple of buttons and “fix” something that could have taken you minutes to correct yourself. Sabbath Mode can inadvertently be activated by pressing the wrong sequence of control panel buttons, kids playing with the control panel and also after a power outage. The “problem” can be cleared, but you will have to find the proper reference in your owner operator manual. Manufacturers provide different procedures for activating and deactivating the mode, so instructions may differ. I hope this helps you.
Anonymous
Level 1:
  • Contributor 2 Answers
  • Posted on Nov 04, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
1316
Points
14
Press the clock botton for 5 seconds
David Del Polito
Level 2:
Habit-Forming:
New Friend:
  • Expert 44 Answers
  • Posted on Jul 11, 2019
David Del Polito
Expert
Level 2:
Habit-Forming:
New Friend:
Answers
44
Questions
0
Helped
19718
Points
108
You are in a Jewish Sabbath Mode setting
In your Manual it should have instructions, if you don’t have the manual I would need the model number to look it up.
Robert Maynard
Level 1:
  • Contributor 1 Answer
  • Posted on Jul 10, 2019
Robert Maynard
Contributor
Level 1:
Answers
Questions
0
Helped
1047
Points
Holding the clock button for 5 seconds fixed our Jennaire. Thank you to the person that told us to do that.
Error code SAb bath on Jenn Air oven. Held clock button down for 5 seconds and key pad still will not work.
possible need new key pad.first check no loose connection from key pad to the control board,if not replace key pad
4helpful
2answers
My oven will not move from SAb o 5A6 and buttons
You have inadvertently entered the Sabbath Mode.
Try holding the clock button for 5 seconds to clear it out.
3helpful
Stove needs to be reset?
Had the same problem...hold the clock button for about 3 or 4 seconds. That should fix it.
It is really SAB for Sabbath instead of 5Ab.
4helpful
2answers
22helpful
4answers
Erroe code 5ab
According to the manual, this mode is SAB and not 5AB. SAB stands for sabath mode and lasts for 72 hours. The mode may be canceled by holding in the clock button for 3 seconds. This mode was activated by holding in the clock button for 3 seconds. My wife did the same thing when resetting the clock for daylight savings time this year. Resetting the power does not reset SAB mode.
61helpful
7answers
Error code 5A6 on Maytag oven MER5755QAB
My range showed a code of 5A6, I held the clock key down for a few seconds and it corrected itself.
Top Jenn-Air Kitchen Ranges Experts
Paul Carew
ZJ Limited
ZJ Limited
Are you a Jenn-Air Kitchen Range Expert? Answer questions, earn points and help others
