Samsung LN-T4061F 40 in. LCD HDTV Logo
Posted on Mar 10, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
OFF-ON, Getting 2 clic after tv shutdown. Take 3
When i turn the tv on, Getting 2 clic after tv shutdown. Takes 3 or 4 times before getting tv on ang getting sound and images
Chi Chu
Level 3:
  • Samsung Master 8,457 Answers
  • Posted on Mar 10, 2010
Chi Chu
Samsung Master
Level 3:
Answers
8457
Questions
0
Helped
2823161
Points
26282
Power supply board is dead.Know how to solders?Check these capacitors for bulge up or pop open,replaced these capacitors will solved this problems.Or can buy a whole reburbish power suppply board at Shopjimmy.com,Ebay.com for the replacement.
Como programarlo recivir fax automatico?
Uso del panel de control de la impresora
1. Pulse el bot?n men?s
2. Busque en Configuraci?n y seleccione Configuraci?n del fax
3. Bajo recepci?n de fax seleccione Configuraci?n Habilitar recepci?n
4. Haga clic en el bot?n de verificaci?n para presentar
Uso del servidor Web incorporado
1. Escriba la direcci?n IP de la impresora en el campo de direcciones del navegador Web.
2. Nota: Si usted no conoce la direcci?n IP de la impresora, imprima una p?gina de configuraci?n de red y busque la direcci?n en
3. la secci?n TCP / IP.
4. Haga clic en Configuraci?n.
5. Haga clic en Configuraci?n de fax.
6. Haga clic en Configuraci?n de fax anal?gico.
7. En Fax recibir los ajustes, por favor marque la casilla de verificaci?n Habilitar recepci?n de fax
8. Haga clic en Enviar.
Nota: traducci?n con Google Translate
1helpful
I have a 1 yr old samsung flat tv that has a sound but no picture..how can i fix it. i am in an isolated island here in basco, batanes philippines with no experts in repairing flat tv.pls advice. tnx
Kung LCD TV ang unit mo, 3 ang dahilan kung kaya la kang picture.
1. Me pundido kang backlight - kapag me pundido kang backlight kusang pinapatay ng power supply ang inverter board para hindi ma-overload kaya la kang picture. Maaring mong i-check ang backlight, ang palatandaan na ito ay pundido ay kapag me itim sa magkabilang dulo.
2. Sira ang inverter board - ang inverter board ang nagbibigay ng high voltage sa backlight. Kapag sira ito, natural d gagana ang backlight. karamihang sira ng backlight ay ang high voltage transformer, driver transistor o kaya me open na fuse/fusible resistor.
3. Power supply- kapag la supply voltage sa inverter board, la ka rin picture. Mas maganda kung ito ang sira dahil mas madali makhanap ng pyesa dyan sa lugar mo di katulad ng 2 nauna.
Kung me kakilala kang technician dyan malapit sa lugar nyo, patingnan mo yong mga sinabi ko. Maari ring dahil sa loose connection kaya la ka picture o kaya bad solder joints.
Salamat kapatid sa pagboto 4 na hinlalaki.
Jdvillanueva
Las Pinas NCR.
Quise instalar activex y resulto que internet explorer entro en conflicto
Resuelve siguiendo estos procedimeintos:
Puedes optimizar internet explorer mediante el seguimiento de los siguientes m?todos: M?todo 1: Borrar datos almacenados en cach? en Internet Explorer Para determinar si es un problema de rendimiento o un mensaje de error motivado por los da?os en los archivos temporales de Internet o en otros en cach? informaci?n que se utiliza Internet Explorer, debes borrar los datos almacenados en cach?. Para Para ello, sigue estos pasos: 1. Abre Internet Explorer 7. 2. Haz clic en Herramientas y, a continuaci?n, haz clic enEliminar Historial de exploraci?n. 3. En Eliminar historial de exploraci?n, haz clic en Eliminar todos. 4. Haz clic para seleccionar el Eliminar tambi?n los archivos y configuraciones almacenados por los complementos la casilla de verificaci?n y, a continuaci?n, haz clic en ACEPTAR. Si sigue produci?ndose problemas, prueba el m?todo 2. M?todo 2: Restablecer la configuraci?n de seguridad para Internet Explorer Si establece la configuraci?n de seguridad demasiado restrictiva, puede impedir que Internet Explorer muestre ciertos sitios Web. Para determinar Si un problema es causado por la configuraci?n de seguridad demasiado restrictiva, vuelve a la configuraci?n de seguridad predeterminada. Para ello, sigue estos pasos: 1. Abre el Explorador de Internet. 2. Haz clic en Herramientas y, a continuaci?n, haz clic enOpciones de Internet. 3. Haz clic en Seguridad . 4. Haz clic en Restablecer todas las zonas al nivel predeterminado, y, a continuaci?n, haz clic enACEPTAR. Despu?s de hacer esto, prueba Internet Explorer para comprobar si funciona correctamente. Si contin?a produci?ndose problemas, intenta con elm?todo 3. M?todo 3: Ejecutar Internet Explorer en modo "Sin complementos" Complementos de Internet Explorer, como controles de ActiveX son utilizados por algunos sitios Web que utilizan las barras de herramientas, para proporcionar una exploraci?n mejorada experiencia. Puede producirse un error si un complemento se da?a o si un complemento entra en conflicto con Internet Explorer. Para determinar si el error se produce por un complemento, que ejecute Internet Explorer intenta abrirlo en modo "Sin complementos".
Para ello, sigue estos pasos: 1. Haz clic en Inicio y, a continuaci?n, escriba Internet Explorer En el cuadro de di?logo Propiedades de Iniciar b?squeda cuadro. 2. Haz clic en Internet Explorer (sin complementos). Internet Explorer se abre sin complementos, barras de herramientas o plug-ins. 3. Prueba Internet Explorer para comprobar que funciona correctamente.
Si contin?a produci?ndose problemas, intenta con el m?todo 4. Si no se producen errores, el problema est? causado por uno de los complementos que normalmente se cargan junto con Internet Explorer. En este caso, utiliza uno de las siguientes opciones. Opci?n 1: Restablecer Internet Explorer Restablece la configuraci?n predeterminada de Internet Explorer. Este paso tambi?n deshabilitar? los complementos, plug-ins y barras de herramientas que est?n instalados. Aunque esta soluci?n es r?pida, tambi?n significa que, si desea utilizar cualquiera de los complementos en el futuro, debe ser reinstalados. Para restablecer la configuraci?n de Internet Explorer, usa el m?todo 4. Opci?n 2: Usar el administrar complementos herramienta para determinar qu? complemento est? causando el problema Utiliza la herramienta Administrar complementos en Internet Explorer para deshabilitar individualmente cada complemento para determinar qu? complemento est? produciendo errores. Para ello, sigue estos pasos: 1. Abre Internet Explorer 7. 2. Haz clic en Herramientas, seleccione Administrar Complementosy, a continuaci?n, haz clic enHabilitar o deshabilitar complementos. 3. En el cuadro Mostrar , selecciona Complementos que han sido utilizados por Internet Explorerpara mostrar todos los complementos que se instalan en el equipo. 4. Para cada elemento de esta lista, selecciona el complemento y, a continuaci?n Haz clic enDeshabilitar en el men? de configuraci?n. 5. Una vez desactivados todos los elementos de esta lista, haz clic en ACEPTAR. 6. Salir y reiniciar Internet Explorer 7. 7. Si no se producen problemas, repita los pasos 1 a 3. 8. Haz clic en Habilitar para un ?nico complemento. 9. Repite los pasos 6 a 8 hasta que averig?es qu? complemento hace que se producen errores. M?todo 4: Restablecer la configuraci?n de Internet Explorer Para determinar si es un problema de rendimiento o un mensaje de error causada por los valores de configuraci?n, restablece la configuaci?n de Internet Explorer a su valor predeterminado. Utiliza esta herramienta para realizarlo autom?ticamente C?mo optimizar Internet Explorer: http://support.microsoft.com/kb/936213/es Si deseas realizarlo manualmente sigue estos pasos: 1. Abre el Explorador de Internet. 2. Haz clic en Herramientas y, a continuaci?n, haz clic enOpciones de Internet. 3. Haz clic en la ficha Avanzada . 4. Bajo Restablecer la configuraci?n de Internet Explorer, Haz clic enRestablecer. Restablecer la configuraci?n de Internet Explorer 7
(http://windowshelp.microsoft.com/Windows/es-es/Help/81fe3b46-2460-459e-b826-8f134a7fe1771033.mspx) M?todo 5: Solucionadores de problemas Internet Explorer en Windows 7 De forma predeterminada, Windows 7 tiene los siguientes solucionadores de problemas de Internet Explorer dos: 1. Rendimiento de Internet Explorer 2. Seguridad de Internet Explorer Ejecuci?n de los solucionadores de problemas de Internet Explorer 1. Cierra todos los programas. Haz clic en Inicio , y luego en Panel de control. 2. Haz clic en Buscar y solucionar problemas bajo Sistema y seguridad. 3. Haz clic en Ver todos en el panel de tareas de la izquierda. 4. Haz clic en Rendimiento de Internet Explorer. 5. Haz clic en siguiente en el cuadro de di?logo. 6. El Solucionador de problemas ejecutar? y corrige autom?ticamente todos los problemas identificados. Haz clic enCerrar.
5helpful
2answers
Power shuts off 1 second after tv is turned on
Good Day,
This model is equipped with a self-diagnosis feature to help with diagnosis of shutdown problems. To activate this turn the unit on let it shutdown then press the input and menu buttons on the front panel simultaneously and hold them in for 5 seconds after 5 seconds the power LED on the front panel will blink a two digit sequence. This will be one set of blinks a short pause then another set of blinks, this will repeat 5 times.
1 - 2 = no error detected
2 - 1 = X-ray protect (high voltage or beam current)
2 - 2 = Short protect (short protect monitors low voltage supplies)
2 - 3 = Deflection protect (this could be loss of vertical or horizontal deflection)
2 - 4 = Vertical protect (usually loss of vertical from the source)
1. SHUTDOWN AT POWER WITH SELF DIAGNOSIS ERROR 2 2. CHECK FOR LEAKY C9A60 470 PF 1000 V PART # 154P400030, PARALLEL TO D9A57 ON THE POWER PCB (NOT SHOWN IN THE SCHEMATIC).
2. SHUTDOWN AT POWER WITH SELF DIAGNOSIS ERROR 2 2. CHECK FOR OPEN FUSES F9A04 AND F9A05 PART # 283P043090 ON THE +24 AND -24 VOLT LINES. IF THE FUSES ARE OPEN THE CONVERGENCE OUTPUT CIRCUIT WOULD BE SUSPECT.
3. SELF-DIAGNOSIS INDICATES SHORT PROTECT. CHECK FOR A SHORTED IC4B01 PART # 270P261020 (VERTICAL OUTPUT) LOADING 24-VOLT SUPPLY LINE. LOCATED ON THE MAIN PCB.
I hope this was helpful, BIG IRISH.
My tv takes a while to tune in when i first turn it on,then it kicks in and after a while it tunes out.
Howdy;
When the TV shuts down try this procedure to try to isolate the problem:
Good Luck, Big Irish
3helpful
TELEVISION WILL NOT TURN ON. WHEN I TURN IT ON EITH MANUALLY OR USING THE REMOTE, I CAN SEE THE LIGHT GO ON, THEN THERE IS A CLICKING SOUND IN THE TELEVISION AND THEN IT TURN OFF,, THIS CYCLE TAKES...
Howdy,
First reset the TV by unplugging from a/c source for about 3-5 minutes. Plug TV back into a/c source. Then TV back on if no fix try this to isolate problem:
This model is equipped with a self-diagnosis feature to help with diagnosis of shutdown problems. To activate this turn the unit on let it shutdown then press the input/device and menu buttons on the front panel simultaneously and hold them in for 5 seconds after 5 seconds the power LED on the front panel will blink a two digit sequence. This will be one set of blinks a short pause then another set of blinks, this will repeat 5 times.
1. MAY BE INTERMITTENT, SELF-DIAGNOSIS ERROR 23 OR 24. CHECK SOLDER CONNECTIONS AT CONNECTOR "DY" ON THE YOKES.
2. SHUTDOWN AT POWER WITH SELF-DIAGNOSIS ERROR 23 OR 24. CHECK C411 2200 UFD 35 V AND C412 10 UFD 50 V, BOTH LOCATED ON THE MAIN PCB.
I hope this helpful, Good Luck, Big Irish.
Patay sinde
Your concern is that the TV turns itself off. This could probably be due to any of several possibilities:
1. cold solder or loose connection, may maluwag na koneksyon sa loob o mayroong hilaw na hinang. Kailangan lamang itong painitan ng soldering iron upang muling manumbalik ang kinang at tamang pagkakapit. May mga pagkakataon na maaring maluwag din ang ACplug sa outlet;
2. heat induced - may pyesa na nag-iinit at tumitigil sa pag-andar pag mainit na. Kadalas ay mga capacitor, transistor or regulator;
3. low supply of the AC mains - mababa ang kuryente, maaring ito ma-check sa pamamagitan ng isang Voltmeter. Kung mababa nga, maaring gumamit ng voltage regulator kagaya ng sa mga computer;
4. timer - may mga pagkakataon na mayroong timer kaya kusang nag-switch off anf TV makalipas ang takdang oras;
Of course repairs would involve knowledge and familiarity with electronics circuitry and components, use of a DVM and a soldering iron. Should you be uncomfortable performing a DIY, perhaps your best bet would be to seek the services of a qualified professional.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
2answers
65 INCH PROJECTION SCREEN IS SUPER BRIGHT
super bright is due to failure in video section. 1 video supply might be absent. 2 g2 voltage mighi be high gue to some part defective at ground side. 3 chroma or jungle ic not getting supply or defective. 4 luminance section defective. BUT AS you are also saying that it came once after hitting on top so there is also possibility of loose contact also. good luck.
Mitsubishi ws 55513 rear projection HDTV
This model is equipped with a self-diagnosis feature to help with diagnosis of shutdown problems. To activate this turn the unit on let it shutdown then press the device and menu buttons on the front panel simultaneously and hold them in for 5 seconds after 5 seconds the power LED on the front panel will blink a two digit sequence. This will be one set of blinks a short pause then another set of blinks, this will repeat 5 times. 1 - 2 = no error detected 2 - 1 = X-ray protect (high voltage or beam current) 2 - 2 = Short protect (short protect monitors low voltage supplies) 2 - 3 = Deflection protect (this could be loss of vertical or horizontal deflection) 2 - 4 = Vertical protect (usually loss of vertical from the source) 1. SHUTDOWN AT POWER WITH SELF DIAGNOSIS ERROR 2 2. CHECK FOR LEAKY C9A60 470 PF 1000 V PART # 154P400030, PARALLEL TO D9A57 ON THE POWER PCB. 2. SHUTDOWN AT POWER WITH SELF DIAGNOSIS ERROR 2 2. CHECK FOR OPEN FUSES F9A04 AND F9A05 PART # 283P043090 ON THE +24 AND -24 VOLT LINES. IF THE FUSES ARE OPEN THE CONVERGENCE OUTPUT CIRCUIT WOULD BE SUSPECT
6helpful
2answers
VS50607 Mitsubishi
This model is equipped with a self-diagnosis feature to help with diagnosis of shutdown problems. To activate this turn the unit on let it shutdown then press the input/device and menu buttons on the front panel simultaneously and hold them in for 5 seconds after 5 seconds the power LED on the front panel will blink a two digit sequence. This will be one set of blinks a short pause then another set of blinks, this will repeat 5 times. 1 - 2 = no error detected 2 - 1 = X-ray protect (high voltage or beam current) 2 - 2 = Short protect (short protect monitors low voltage supplies) 2 - 3 = Deflection protect (this could be loss of vertical or horizontal deflection) 2 - 4 = Vertical protect (usually loss of vertical from the source.....
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
