FixYa.com
Mitsubishi VS-50607 50 in. Rear Projection Television
All Products > Mitsubishi > Projection Televisions
Problems with Mitsubishi VS-50607 50 in. Rear Projection Television?
Troubleshooting and Support
Solved Problems for Mitsubishi VS-50607 50 in. Rear Projection Television RSS Feed Post a New Problem
Mitsubishi Tv model#CS-2655 ...
How do I unlock these channels
1 Solution
lose picture
I lose the picture from time to time, no particular pattern to it. Sound is fine. Sounds like a small fix but have no...
1 Solution
mitsubishi rear projection tv model...
My tv turns on for 1 second then off right away. I pushed input and menu and it gives me a 2-1 code on the power button....
1 Solution
VS50607 Mitsubishi
My tv started off not turning on intermittantly. Now it doesn't turn on. it's like it isn't getting any power. i checked...
1 Solution
Diagnosis 23
My TV now turns on and then off right away. I get a 2-3 when diagnosing the problem. This is what I would like to ask:...
1 Solution
Black box in the middle of my mitsubishi...
My mitsubishi tv has a black box right in the middle of it. Whenever I try to adjust it, like do picture in picture or...
2 Solutions
mits m#vs-5007r convergence not inline
replaced stk 4274 red now looks great but can not get the whole thing in line looks great in center i can adjust all...
1 Solution
View All
Unsolved Support Problems
Unsolved Problems for Mitsubishi VS-50607 50 in. Rear Projection Television RSS Feed Post a New Problem
Green Screen
Whenever I hook up either the xbox 360 or ps 3 to this tv using component av cables, I get a green screen, is there...
Post a Solution
mitsubishi vs 50607
tv turns off sometimes turns right back on sometimes it takes a while i did the test and get a 2 4 code how do i go...
Post a Solution
mitsubishi vs-50607
mitsubishi model # vs-50607 manufactured in March 2000,Tv has started acting up since thunderstorm we had,tv will come...
Post a Solution
Diagnosis is 12. Power ON, no image, no...
It started today. Out of the blue tv set would turn on but no picture or sound. Tried cycling through the inputs with no...
Post a Solution
Older 1080 HDTV Rear Projection
I have a 50 Inch older 1080 HDTV Rear Projection. We were hit with a lightning power surge. The TV turns on, the screen...
Post a Solution
shut off.
I have a 50" Mitsubishi, sorry I do not know the model #. It was working fine and it just shut off. Now the green...
Post a Solution
NEED HELP
I THINK MY CODE IS 2-3 I NEED TO KNOW WHAT TO DO?WORKED FINE YESTERDAY WHILE WATCHING TV SOMEONE THOUGHT THEY HIT TIMER...
Post a Solution
View All
Tips & Tricks
Post a New Tip
Specifications
Key Features
Screen Size50 inch
Audio Features
Secondary Audio Programming (SAP)Without SAP
Mitsubishi Contact Information
Main support number800-332-2119
Support FAX(714) 229-3854
Email supportCustomerCare@meus.mea.com
Sponsored Links
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
