Cars & Trucks Logo
Posted on Mar 06, 2010
Just bought a 1986 Cadillac De Ville. doesn't seem to be getting gas. need to know where the fuel filter is located. It is a V-8 4.1 engine.
Anonymous
Level 1:
New Friend:
  • Contributor 2 Answers
  • Posted on Mar 06, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
2611
Points
Radio will not shut off when pull the key out of a 2000 kia sportage
1995 Cadillac sedan de Ville seems to be lacking low end power starting out and at increased speed ??
catalytic converter fuel filter...ethanol destroys..
air filter...clogged injectors
1helpful
Can't open the back doors on 86 cadillac de ville
Automatic ?? You should be able to unlock the doors from the inside and open them. If someone set the child safety locks you may have to remove the door panels and unlock from the inside of the doors.
2answers
I need to find out the right order to put my spark plugs the firing order its a v 8 4.1 litter my brother got them all mixed up.
The firing order for a 4.1 V-8 is 1-8-4-3-6-5-7-2. Odd number pistons are on the driver's side, front to back and even numbers on the passenger's side front to back. The distributor turns counter-clockwise (backwards) and #1 piston is at 1 o'clock (close to the firewall). Hope this helps.
I need a diagram of how to put a steering column back together
Ok It Possible to download it.. From LimeWire To do So Type
Exemple ..Download Cadillac Sedan de Ville 1986 Steering Diagram utility ..then take the one you need ...Good Luck
What would be the most common problem besides the fuse, that my fans are not working and thus may be the reason my car is overheating and the solution to it. I have a 1986 Cadillac De Ville 4 Door V 8. I...
It could be several things.
1. Fan relay, as this controls power to the fan.
2.Blown fuse or tripped circuit breaker, usually both located in the fuse panel
3. Thermostat that tells the fan relay to start based on heat at the radiator.
Each of these need to be verified as working properly prior to any additional troubleshooting.
1helpful
My 1992 Coup de ville cuts out when it gets down to 8 gallons or less. Why? Other wise runs great. Fuel pump maybe? Thank you, Mark D. Johnston
a fuel pressure gauge to check the pressure sort of a special tool a fuel filter may cause something along these line of symptoms but it would be at any fuel level for the filter. The only way to really know is the pressure when it happens
2answers
1994 Cadillac De Ville acts like vaporlock
change fuel filter and check fuel pressure.sound like low fuel pressure problems.
1helpful
Secondary pump 86 de ville
Sounds like your talking about an engine air pump. If so and its not belt driven then it will run while the engine runs.
Top Cadillac Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Sean Wright
Sean Wright
Are you a Cadillac Expert? Answer questions, earn points and help others
