Microsoft Excel for PC Logo
Anonymous Posted on Mar 04, 2010
Formula for cell that is not blank
I have a three sheet Excel document on sheet 3 if AM2 is not blank I need a value of x on Sheet 1 D1. Any assistance would be greatly appreciated.
Anonymous
Level 1:
New Friend:
  • Contributor 18 Answers
  • Posted on Mar 05, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
18
Questions
0
Helped
5346
Points
25
You can use IF and ISBLANK. Put this formula on Sheet 1 D1:
=IF(ISBLANK(Sheet3!AM2),"x","")
You can replace "x" by any other value you need.
Need formula for Excel
Try using "count if blank"
I am assuming that you need the value to be on sheet 3
If you want the value to be on another sheet, it is more complicated, you will have to "paste special" the value to a different sheet.
1helpful
Copy data that contains formula and paste it to a new sheet minus the formula: is this possible?
Sure is - depending on your version of Excel.
1) right click on the cell with the formula
2) go to where you want to paste the value - minue the formula
3) right click and select paste special
4) click values (as seen in image below)
and that's it done.
If this helped you, then please help me and vote kindly.
In Excel trying to compare two ranges
I imagine that the only way is with VBA coding. This is possible if you know programming in Excel (VBA - Visual Basic for Applications).
1helpful
2answers
Formula not working correctly
You need to change the =IF(AND to =IF(OR
Using AND is saying both conditions must be true. Using OR is saying either condition 1 or 2 need to be true
1helpful
I need a formula based on the value of two cells
You were of to a good start. Try using the AND function in the IF Formula as follows:
=IF(AND(Sheet3!H2="Clark College",ISBLANK(Sheet3!I2)),"X"," ")
Excel formula related to a date range
Use the IF and Date functions together. On sheet 3, put the birthday (3/15/1954) in cell B1, put the beginning date (1/1/1946) in cell C1 and the ending date (12/31/1964) in cell D1.
Then on Sheet 1, but the following formula in the cell you want an X to be placed in.
=IF(AND(Sheet3!B1>=Sheet3!C1,(Sheet3!B1<=Sheet3!D1)),"X"," ").
Make sure you type the formula Exactly as it appears.
4helpful
5answers
How to use vlookup in openoffice using different sheets
=VLOOKUP(A2;Sheet1.$A$3:D27;2;0)
The cell I created this formula in was Sheet 3 Cell C9 - to show the different sheets
A2 is the cell I want to look up
Sheet1.A3:D27 is the range of cells that contains the data I want to return, The first column relates directly to cell C9 is Sheet 3. I locked the first cell in my range as I wanted to apply the same formula across other cells hence the $
2 is the number of the column that has the data I want to return, I had a choice in this formula of 4 columns
0 is the value to complete the formula
2helpful
4answers
How to connect one sheet to another sheet
how i connect one excel sheet to another excel
2answers
Excel formulas
type in "=" and then go to the cell in the 2nd sheet and click on the cell that contains the value you want carried to sheet 1. Then drag copy the forumula in sheet 1 to all the cells you want it to relate to. Now, if you place a value in e.g. A1 of sheet 2, then that same value will appear in A1 of sheet 1.
Good luck.
Copying data from one sheet to another if two fileds match
Nope, sorry, although I am truly an expert at Excel formulas, I do not understand what you are trying to end up with in the final cell. We can compare a specified field with two spreadsheets - use named ranges and index/match lookup formulas. But then where you really lose me is in reading "a generic field" to find a match, and then placing what "data from another field" into what "other sheet" - ? See the confusion?
Best way to compare 2 given parameters would be to use a nested if formula, with index/match combo. Here is a simple Excel example of how such a formula could be structured:
Sample Data (columnar arangement):
A1: Part B1: Code C1: Price D1: Find Part E1: Find Code
A2: x B2: 11 C2: 5.00 D2: y E2: 12
A3: x B3: 12 C3: 6.00 D3: y E3: 11
A4: y B4: 11 C4: 7.00 D4: x E4: 12
A5: y B5: 12 C5: 8.00 D5: x E5: 11
To retrieve the price for part y with code 12 and return the value to cell F2, type the following formula in cell F2:
=INDEX($C$2:$C$5,MATCH(D2,IF($B$2:$B$5=E2,$A$2:$A$5),0))
Press CTRL+SHIFT+ENTER to enter the formula as an array formula. The formula returns the value 8.00.
To take this one step further, with range names, this example will find one value at a specified location which matches a specific row header value and column header value. Let's say the range is home values (Range=HomeVal), Column A of HomeVal contains street addresses,"row headers" (Range=StAddress), and Row 1 contains dates of the various values that are in the body of the table, "column headers" (Range=Dates). To return the specific value from the range HomeVal to another sheet, where A1=address specified and A2=date specified:
=INDEX(HomeVal,(MATCH($A$1,StAddress,0)),(MATCH($A$2,Dates,0)))
Then make sure to press CTRL+SHIFT+ENTER to enter the formula as an array formula - if you only hit enter, these types of formulas will not work properly.
Please post back if you need further help, with more details, otherwise thank you for using and rating FixYa!
Top Microsoft Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
