Check the hydraulic fluid to your clutch master cylinder. If it's low you may have a warn clutch or a leak in the system, and most likely at the clutch slave cylinder. Try adding more fluid if it's low and bleeding the system, at worst your going to need to replace the clutch. Also it would not hurt to check your transmission fluid or better yet service it to replace the oil transmission fluid with new fluid. You'll find the fill and drain bolt at the side of the transmission. Good luck and keep me posted, thank you for using Fixya.
